On the Properties view Help tab, you can create context-sensitive, online help in the Web client by selecting a language and defining the help topic and text.
| Field | Use |
| Language | You can declare Information behaviors specific to a given language by using the optional Language attribute. If this attribute is set, OSM automatically selects the appropriate instance using the user's language preferences set in the Web Browser. |
| Topic | Enter the topic name for this help message. |
| Message | Enter the help documentation that will be displayed in the Web client when the user clicks the associated field Help button.
Note: Use valid HTML to enter the help message. |
