Use the Testing tab to view ASAP test cases that you created for your projects and run them individually or simultaneously.
| Field | Use |
| Environment | Select a Studio environment that has configuration for an ASAP environment. |
| Include all from Project | Select to include all test case entities. |
| Entity | Displays activation test case entities. |
| Status | Displays the status of a work order. |
| Run All | Click to execute all test cases one by one in the Studio environment. |
| Separate Console for each Test Case | Select to open a different console window for each test case in a Studio environment. |
| Select | Click to add a test case entity from the project. |
| Open | Click to open a specific test case entity. |
| Remove | Click to clear a specific test case entity from the Testing tab. |
| Run | Click to execute a specific test case. |
