Voltage Alarms
The following table lists the voltage alarms.
Table 6-5 Voltage Alarms
| Alarm | Alarm Severity | Cause(s) | Log Message | Graphic Display Window Message |
| SD5_VOLTAGE_HIGH_MAIN | EMERGENCY
outside 30% of normal voltage MINOR: outside 10% of normal voltage |
Faulty POL that is not operating correctly | Voltage: XX.XXV (Where XX.XX is the voltage in volts) | POL X is at Y volts, outside minor/emergency threshold of Z1 to Z2 (Where X is sensor name, Y is voltage and Z is threshold) |
| SD5_VOLTAGE_HIGH_PHY0 | EMERGENCY
| SD5_VOLTAGE_HIGH_PHY1 | EMERGENCY
| SD5_VOLTAGE_HIGH_PHY2 | EMERGENCY
| SD5_VOLTAGE_HIGH_FLEX1 | EMERGENCY
| SD5_VOLTAGE_HIGH_FLEX2 | EMERGENCY
| SD5_VOLTAGE_HIGH_MGMT | EMERGENCY
| SD5_VOLTAGE_HIGH_TLS0 | EMERGENCY
| SD5_VOLTAGE_HIGH_TLS1 | EMERGENCY
| SD5_VOLTAGE_HIGH_TLS2 | EMERGENCY
