Installation and Removal Guidelines
Please read and follow these guidelines prior to installing or removing the Transcoding Module (TM):
- The TM can be installed only in the designated location.
- Note the installation locations of the TM on the TCU.
- Ground yourself and follow proper ESD grounding procedures.
- Remove the TM from the shipped packaging.
- Remove and install the TM according to the procedures below.
- This upgrade should be performed during low-traffic periods or during times of scheduled maintenance.
- Follow industry-standard procedures to ensure ESD protection.
- When installing or removing a TCU, move the card to an ESD-safe location.
Before handling an Acme Packet 6300/6350 TCU, follow the proper ESD grounding procedures. Failure to do so could damage the TCU and its components.
