Pre-Installation Guidelines
Please read and follow these pre-installation guidelines prior to replacing the SSM3 module:
- The SSM3 module can be installed only in the designated location.
- Note the installation location of the SSM3 module on the NIU PCB.
- Ground yourself and follow proper ESD grounding procedures.
- Remove the SSM3 from the shipped packaging.
- Install the SSM3 according to the procedure below.
- This upgrade should be performed during low-traffic periods or during times of scheduled maintenance.
- Follow industry-standard procedures to ensure ESD protection.
- When installing or removing an NIU card, move the card to an ESD-safe location.
Before handling a Acme Packet 6300/6350 NIU card, follow the proper ESD grounding procedures. Failure to do so could damage the NIU card and its components.
