About This Guide
The Acme Packet 6300/6350 is a high performance, high capacity session border controller that optimally delivers interactive communications — voice, video, and multimedia sessions — across wireline, wireless, and cable IP network borders. With its 3U design the Acme Packet 6300/6350 provides exceptional functionality in a tightly integrated system. This chapter provides an introduction and overview of the Acme Packet 6300/6350 main components.
Oracle Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc .
Revision History
This section contains a revision history for this document.
| Date | Revision Number | Description |
| September 28, 2012 | Revision 1.0 | First Draft Acme Packet 6300 Hardware Installation Guide |
| September 29, 2012 | Revision 1.1 | Added updates to document |
| October 3, 2012 | Revision 1.2 | Added updates to the Alarms section |
| October 4, 2012 | Revision 1.3 | Added updates to the Boot Parameter section |
| October 5, 2012 | Revision 1.4 | Added updates to the Alarms section |
| November 14, 2012 | Revision 1.5 | Added updates to the power source
sections Acme Packet 6300 Hardware Installation and Maintenance Guide
Added VCCI-B Certification |
| December 18, 2012 | Revision 1.6 | Added the halt command
Added the terminology Storage Device Changed a picture in the mounting section |
| January 9, 2013 | Revision 1.7 | Added the locking mechanism to the guide rail section. |
| Mat 7, 2013 | Revision 1.8 | Added reference connect NIU removal |
| May 9, 2013 | Revision 1.9 | Updated Optical Trans section |
| Aug 16, 2013 | Revision 1.10 | Updated Specification section |
| November 11, 2013 | Revision 1.11 | Removed all instances of Net-Net |
| February 24, 2014 | Revision 1.12 | Added these new sections:
- TCM
Removal and Replacement
- Replacing the SSM3 Module
- Installing SODIMMs
Replacing Transcoder DSP Modules
- Replacing the SSD
Formatted photos and tables to conform to new standard |
| October 16, 2014 | Revision 1.13 | Changed references to Media
Ports from GigE to 10GbE to clarify Media Port speed.
Updated Heat and Power Dissipation information in the Specifications chapter. |
| November 10, 2014 | Revision 1.14 | Entered a note in the
Maintenance Introduction pointing out that after you replace an SSD, you must
format it.
Corrected VCCI references. |
| January 15, 2015 | Revision 1.15 | Renamed the document to reflect
the merge of the Installation and Service manuals.
Removed Regulatory Specifications and Certifications from the Specifications chapter. Inserted reference to Acme Packet Platforms Safety and Compliance Guide. Inserted an updated Oracle copyright page. |
| April 20, 2015 | Revision 1.15 | Inserted language to confirm
that Acme Packet 6300 hardware installation documentation satisfies NEBS
(Network Equipment-Building System) requirements.
Entered a note at the end of the Startup chapter pointing out that after you initially sign on to an Acme Packet 6300 after installation, you must format the solid state drive. |
| August 8, 2017 | Revision 2.00 |
Adds support for Acme Packet 6350. |
| January 11, 2019 | Revision 2.10 | Adds the Oracle accessibility statement to "About This Guide". |
