Reset Button
Reset the Acme Packet 6300/6350 by pressing the front panel’s reset button. This button is recessed, and can only be pressed by inserting a thin wire, such as a paper clip, through the reset button channel. Accidentally pressing the reset button can result in the loss of software data or your configuration.
Pressing the reset button causes a hard reset, immediately
rebooting the
Acme Packet 6300/6350.
After the reset button is released, the
begins its boot sequence and loads the configured software file.
