Precautions
- Note the locations of the power supply switches on the Acme Packet 6300/6350.
- Note the location of the emergency power-off switch for the room where the Acme Packet 6300/6350 is located.
- If an electrical accident occurs, remove power from the system immediately by unplugging the chassis.
- Always disconnect the power from the system when removing a Acme Packet 6300/6350 from its rack.
- When disconnecting power:
- Disconnect the circuit breaker at the rack.
- Unplug or unscrew the power cords from the power supplies.
- Use grounded AC power cords that are plugged into grounded electrical outlets.
- Never use extension cords to power a Acme Packet 6300/6350.
- Ensure that the installation facilities have proper grounding systems and include a grounded rack structure or local grounding bus bar.
- When installing the Acme Packet 6300/6350 in an equipment rack, always make the ground connection first and disconnect it last upon uninstallation.
- Use shielded Category 5e or 6, RJ45 cables for all 10/100/1000 Ethernet connections to protect the Acme Packet 6300/6350 from potential damage.
- To avoid making a complete circuit (which causes electrical shock), use only one hand when working with powered-on electrical equipment.
- Use caution when using electrically conductive tools around the Acme Packet 6300/6350.
- Remove jewelry before working on the Acme Packet 6300/6350.
