Initial Login
Once you have established the console connection, powered on the Acme Packet 6300/6350 and a runtime image has been loaded, you are ready to log in and begin configuring the system. After the Acme Packet 6300/6350 System has been initialized, the ACLI login prompt appears in your terminal application as follows:
User Access Verification Password:
If the Acme Packet 6300/6350 completed booting before you connected to the console port, press the Enter key on the console keyboard a few times to activate the console connection.
System access in the following procedure uses the default User and Superuser passwords. If you do not have the default passwords, please contact your customer support representative.
