Console Port Pin-out
The Acme Packet 6300/6350 System console port is accessed through the RJ45 jack in the rear of the system. Because the Acme Packet 6300/6350 does not employ any type of flow control on its RS-232 ports, only the RX, TX, and GND pins are used. The following table identifies the pin assignments and signal names/descriptions for the console connector.
Table 2-1 Console Port Pin-Out
| Pin Number | Signal Name/Description |
| 3 | Receive Data (RX) |
| 4 | Ground (GND) |
| 6 | Transmit Data (TX) |
