Installing a Power Supply Note:NEVER power up a power supply before it is installed in the Acme Packet 6300/6350 chassis. Ground yourself with an ESD wrist strap before installing a power supply. To install a power supply in the Acme Packet 6300/6350 chassis: Locate the power supply to be installed. Locate the empty power supply slot in the chassis. Insert the power supply into the empty power supply slot located on the rear panel of the Acme Packet 6300/6350 chassis. Installing the Power Supply Push the power supply handle until the power supply is engaged with the chassis. The power supply is installed in the Acme Packet 6300/6350 chassis. Note:Connect the power cord to the inserted power supply.
