Graphic Display
To the left the 4-line graphic display on the Acme Packet 6300/6350 front control panel is visible at all times. To the right the buttons used to navigate the display are accessible as well. The graphic display reports real-time status, alarms, and general system information. You can view this information without using a console, telnet, or SSH connection into the Acme Packet 6300/6350.
