PreviousNextJavaScript must be enabled to correctly display this content
Removing the SSD
The procedure in this section describes how to remove the
SSD from the
Acme Packet 6300/6350.
Prerequisites:
Place the SSD
in an ESD-safe location.
Wear an ESD
wrist strap or take similar equivalent actions to prevent static damage to the
SSD or other ESD-sensitive components.
To remove an SSD:
Using a #2 Phillips
screwdriver, unscrew the two captive screws located on each side of the face of
the SSD. The screws are spring-loaded and will push forward, but they will not
fall out of the door.
Loosening SSD Screws
Pull on one of the
two captive screws and support the base of the SSD as you pull it out of the
chassis to remove it. Please place the removed SSD in an ESD-sensitive
location.
