Installing the Stationary Slides
In this first stage of system installation, you secure the stationary slide to the equipment rack. The end with three mounting slots on the stationary slide rail is attached to the front of the equipment rack and the bare steel side is attached to the rear of the equipment rack. The stationary slide rail can expand and contract to accommodate equipment racks of various depths.
You can mount the stationary slide rail to both tapped hole rack slide rails and square rack slide rails. Follow the appropriate procedure below.
