SFP+ Information
Only transceivers qualified by Acme Packet can be used in the Acme Packet 6300/6350. Mixed transceiver types are unsupported. Both transceiver locations must be populated with the same SFP+ type.
The SFP+s are inserted into the NIU card. These SFP+ types can be used:
- 850nm LASER PROD — check the label on the back of the SFP+ for this information to make sure you have the right mode transceiver. This multi mode SFP+ features a black bale clasp latch.
- 1310nm LASER PROD — check the label on the back of the SFP+ for this information to make sure you have the right mode transceiver. This single mode SFP+ features a blue bale clasp latch.
