Rear Panel
Power supplies and the Option Cards are located in the rear of the chassis. There is a slight difference in the rear chassis of the Acme Packet 6300 and Acme Packet 6350. The Acme Packet 6350 has a System Power switch, which enables you to control the power to the Acme Packet 6350. This is useful when you want to shut off power to the Acme Packet 6350 without having to unplug the power cord. The Acme Packet 6300 does not have a System Power switch.
The System Power switch has the following switch settings:
- STBY—when selected, the Acme
Packet 6350 powers down. While the system is in standby mode, the power supply
remains active, and the fans inside of the power supply run as necessary. The
fans in the front of the chassis do not run. This convenient feature enables
the system to be shut down without having to withdraw the power supply or
disconnect the power supply cord.
Standby mode (STBY) is not the same as standby state. Standby state refers to the system state of a Acme Packet 6350 that is part of a high availability pair (HA pair). - ON—applies power to the Acme
Packet 6350. This switch position is used during normal operation.
Caution:
The System Power switch should remain in the ON position at all times. Do not touch a System Power switch unless specifically instructed to do so by your customer support representative or you are following instructions in this guide.
Two LEDs are present under the System Power switch:
- STBY—This LED is enabled when the system is in standby power mode. The LED is inactive when the system is powered up and running.
- DIS—- This LED is enabled when the console serial port is disabled via software. The LED is inactive when the serial console port is enabled.
Acme Packet 6300 Rear View with AC Power Supplies and Option Cards
Acme Packet 6350 Rear View with AC Power Supplies and Option Cards
The Acme Packet 6350's rear external USB 3 port is not functional.
