ENVIRONMENT Menu
The ENVIRONMENT menu allows you to view information about the hardware’s operational status. The graphic display presents the following information in the order listed:
- Screen 1 — Hardware alarms and link alarms:
HW ALARM: 0
LINK ALARM: 2
- Screen 2 — System temperature and fan speeds:
TEMPERATURE: 38.00 C
FAN SPEEDS:
100% 100% 100% 100% 100%100%100%100%100%100%100%100%100%
100%100%
- Screen 3 — System voltages:
VOLTAGES (V):
1.099, 1.186
1.488, 1.790
2.458, 3.278, 4.982
To exit the ENVIRONMENT menu in the graphic display:
- From the top menu of the graphic display, press the Enter button.
- Press the Up or Down buttons to scroll to the ENVIRONMENT selection.
- Press the Enter button. The ENVIRONMENT information is displayed.
- Press the Up or Down button to scroll to the RETURN selection.
- Press the Enter button to return to the Top Menu.
