Alarm Display
The alarm display replaces the base display during an alarm condition. The alarm display informs you of what symptoms are currently causing alarms. The number and type of alarms appear on the Acme Packet 6300/6350 graphic display, which indicates either a link alarm or a hardware alarm. For example, if there are two link alarms present on the Acme Packet 6300/6350, the display appears like this:
2 LINK ALARMS
If the graphic display indicates an alarm condition, you can use the ACLI display-alarms command to display the details of the alarm. When an alarm condition is cleared, the base display replaces the alarm display. To clear an alarm, you must execute the ACLI clear-alarm command or resolve the cause of the alarm.
