SFP+ Presence Alarms
The following table lists the alarms that reflect when an SFP+ module is inserted or removed from an NIU:
Table 6-8 SFP+ Presence Alarms
| Alarm Name | Alarm Severity | Cause(s) | Example Log Message | Graphic Display Message |
| SFP+ REMOVED GIGPORT 0 | CRITICAL | S0P0 SFP+ Removed | Slot 0 Port 0 SFP+ Removed | N/A |
| SFP+ INSERTED GIGPORT 0 | CRITICAL | S0P0 SFP+ Inserted | Slot 0 Port 0 SFP+ Inserted | N/A |
| SFP+ REMOVED GIGPORT 1 | CRITICAL | S1P0 SFP+ Removed | Slot 1 Port 0 SFP+ Removed | N/A |
| SFP+ INSERTED GIGPORT 1 | CRITICAL | S1P0 SFP+ Inserted | Slot 1 Port 0 SFP+ Inserted | N/A |
| SFP+ REMOVED GIGPORT 2 | CRITICAL | S0P1 SFP+ Removed | Slot 0 Port 1 SFP+ Removed | N/A |
| SFP+ INSERTED GIGPORT 2 | CRITICAL | S0P1 SFP+ Inserted | Slot 0 Port 1 SFP+ Inserted | N/A |
| SFP+ REMOVED GIGPORT 3 | CRITICAL | S1P1 SFP+ Removed | Slot 1 Port 1 SFP+ Removed | N/A |
| SFP+ INSERTED GIGPORT 3 | CRITICAL | S1P1 SFP+ Inserted | Slot 1 Port 1 SFP+ Inserted | N/A |
| SFP+ REMOVED
GIGPORT 4 |
CRITICAL | S2P0 SFP+ Removed | Slot 2 Port 0 SFP+ Removed | N/A |
| SFP+ INSERTED
GIGPORT 4 |
| SFP+ INSERTED
GIGPORT 5 |
CRITICAL | S2P1 SFP+ Removed | Slot 2 Port 1 SFP+ Removed | N/A |
| SFP+ REMOVED
GIGPORT 5 |
When an SFP+ module is inserted or removed from an NIU, there is no impact on system health.
