Your browser does not support JavaScript!
You are here: Transaction Rules > Transaction Elements > Assignment Elements > GrossFullWithdrawalWithAllocations
Description
The GrossFullWithdrawalWithAllocations assignment type, located in the transaction XML, is used to withdraw money from funds. Allocations on the activity at the time of assignment are used to reduce the contract value first. Any remaining amount that must be assigned is distributed amoung the remaining funds on the contract at a ratio of the fund value to the total remaining fund value %. This is similar to GrossFullWithdrawal.
GrossFullWithdrawalWithAllocations Assignment Type
Type
Type
Allocations needed?
Yes
Attributes
SURRENDERCHARGE
Yes, No or a field that holds 'Yes' or 'No'. Determines whether or not a surrender charge is applied.
SURRENDERMONEYTYPE
The type of money for the surrender charge.
MVACHARGE
Yes, No or a field that holds 'Yes' or 'No'. Indicates whether there is an MVA Charge.
MVAMONEYTYPE
The MVA money type.
REDEMPTIONFEE
Yes or No. Indicates whether there is a redemption fee.
REDEMPTIONMONEYTYPE
The redemption fee money type.
FUNDOVERFLOWMONEYTYPE Specifies the money type code of the fund overflow.
BUCKET
The bucket for the EIFund. Must be an integer value.
Element Value
Assignment fields must be negative (removals). The allocation records should be positive and must match the total money-out amount/units or 100%. This is similar to PartialWithdrawal, but the charges are applied within the removal amount.
Assignment fields must be negative (removals). Allocations on the activity at the time of assignment are used to reduce the contract value first. Any remaining amount that must be assigned is distributed amoung the remaining funds on the contract at a ratio of the fund value to the total remaining fund value percent. This is similar to GrossFullWithdrawal.
Used when
Total Money-out
Examples
FreeLook
XML Example
<Assignment TYPE="GrossFullWithdrawalWithAllocations" SURRENDERCHARGE="Yes"
SURRENDERMONEYTYPE="07" MVACHARGE="Yes" MVAMONEYTYPE="3" FUNDOVERFLOWMONEYTYPE="16">
<MoneyType NAME="GMDBChargeDueRemoved">95</MoneyType>
<MoneyType NAME="GMWBChargeDueRemoved">94</MoneyType>
</Assignment>
Copyright © 2009, 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices
