Skip Navigation Links
Exit Print View
Oracle® ZFS Storage Appliance Administration Guide
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 Oracle ZFS Storage Appliance Overview
Chapter 2 Status
Chapter 3 Initial Configuration
Chapter 4 Network Configuration
Chapter 5 Storage Configuration
Chapter 6 Storage Area Network Configuration
Chapter 7 User Configuration
Chapter 8 Setting ZFSSA Preferences
Chapter 9 Alert Configuration
Chapter 10 Cluster Configuration
Chapter 11 ZFSSA Services
Chapter 12 Shares, Projects, and Schema
Understanding Shares
Storage Pools
Using Shares
Share Properties
Share Snapshots
Share Clones
Shares Space Management
Shares Space Terminology
Understanding Snapshots
File System and Project Settings
Data Quotas
Data Reservations
Space Management for Replicating LUNs
User and Group Settings
Viewing Current Usage
Viewing Current Usage in the BUI
Viewing Current Usage in the CLI
Setting User or Group Quotas
Set User or Group Quotas Using the BUI
Set User or Group Quotas Using the CLI
Identity Management
Filesystem Namespace
Namespace Nested Mountpoints
Namespace Protocol Access to Mountpoints
Namespace NFSv2 / NFSv3
Namespace NFSv4
Namespace SMB
Namespace FTP / FTPS / SFTP
Namespace HTTP / HTTPS
Shares > Shares
Working with Shares > Shares in the BUI
List of Shares
Editing a Share
Usage Statistics
Static Properties
Shares Project Panel
Creating a Share
Working with Shares > Shares in the CLI
Navigation
Share Operations
Shares > Shares CLI Properties
Shares > Shares > General - BUI Page
Space Usage
Volume Size
Thin Provisioned
Mountpoint
Read only
Update access time on read
Non-blocking mandatory locking
Data deduplication
Data compression
Checksum
Cache Device Usage
Synchronous Write Bias
Database Record Size
Additional Replication
Virus Scan
Prevent Destruction
Restrict Ownership Change
Custom Properties
Shares > Shares > Protocols - BUI Page
Shares Protocols
Share Protocols - NFS
Share Protocols - CLI
Security Modes
Character Set Encodings
Shares - SMB
Shares - iSCSI
Shares - HTTP
Shares - FTP
Shares - SFTP
Shares > Shares > Access
Access Control
Shares - Root Directory Access
Shares - User
Shares - Group
Shares - Permissions
Shares - ACL Behavior
ACL Behavior on Mode Change
ACL Inheritance Behavior
Root Directory ACL
Shares - Snapshots
Shares - Snapshot Properties
.zfs/snapshot visible
Scheduled Snapshot Label
Listing Snapshots Using the BUI
Manual Snapshots Using the BUI
Create a project level snapshot
Create a share/LUN level snapshot
Renaming a Snapshot (BUI)
Destroying a Snapshot (BUI)
Rolling back to a Snapshot (BUI)
Cloning a Snapshot (BUI)
Scheduled Snapshots Using the BUI
Manual Snapshots Using the CLI
Listing Snapshots (CLI)
Taking Manual Snapshots (CLI)
Renaming a Snapshot (CLI)
Destroying a Snapshot (CLI)
Rolling back to a Snapshot (CLI)
Cloning a Snapshot (CLI)
Listing Dependent Clones Using the CLI
Scheduled Snapshots Using the CLI
Setting the Scheduled Snapshot Label Using the CLI
Projects
Working with Projects Using the BUI
Project Fields
Editing a Project
Usage Statistics
Static Properties
Creating Projects
Working with Projects Using the CLI
Navigation
Project Operations
Selecting a Pool in a Cluster
Project Properties
Project - General
Project - General Properties
Project - Space Usage
Project - Quota
Project - Reservation
Project - Inherited Properties
Project - Custom Properties
Filesystem Creation Defaults
LUN Creation Defaults
Project Protocols
Project Access
Project Snapshots
Project Snapshot Properites
Schemas
Customized Share Properties
Working with Schemas in the BUI
Configuring a Schema Using the BUI
Working with Schemas Using the CLI
Configuring a Schema Using the CLI
Chapter 13 Replication
Chapter 14 Shadow Migration
Chapter 15 CLI Scripting
Chapter 16 Maintenance Workflows
Chapter 17 Integration
Index
The simplest way of enforcing quotas and reservations is on a per-project or per-filesystem basis. Quotas and reservations do not apply to LUNs, though their usage is accounted for in the total project quota or reservations.
Data Quotas
A data quota enforces a limit on the amount of space a filesystem or project can use. By default, it will include the data in the filesystem and all snapshots. Clients attempting to write new data will get an error when the filesystem is full, either because of a quota or because the storage pool is out of space. As described in the snapshot section, this behavior may not be intuitive in all situations, particularly when snapshots are present. Removing a file may cause the filesystem to write new data if the data blocks are referenced by a snapshot, so it may be the case that the only way to decrease space usage is to destroy existing snapshots.
If the 'include snapshots' property is unset, then the quota applies only to the immediate data referenced by the filesystem, not any snapshots. The space used by snapshots is enforced by the project-level quota but is otherwise not enforced. In this situation, removing a file referenced by a snapshot will cause the filesystem's referenced data to decrease, even though the system as a whole is using more space. If the storage pool is full (as opposed to the filesystem reaching a preset quota), then the only way to free up space may be to destroy snapshots.
Data quotas are strictly enforced, which means that as space usage nears the limit, the amount of data that can be written must be throttled as the precise amount of data to be written is not known until after writes have been acknowledged. This can affect performance when operating at or near the quota. Because of this, it is generally advisable to remain below the quota during normal operating procedures.
Quotas are managed through the BUI under Shares -> General -> Space Usage -> Data. They are managed in the CLI as the quota and quota_snap properties.
Data Reservations
A data reservation is used to make sure that a filesystem or project has at least a certain amount of available space, even if other shares in the system try to use more space. This unused reservation is considered part of the filesystem, so if the rest of the pool (or project) reaches capacity, the filesystem can still write new data even though other shares may be out of space.
By default, a reservation includes all snapshots of a filesystem. If the 'include snapshots' property is unset, then the reservation only applies to the immediate data of the filesystem. As described in the snapshot section, the behavior when taking snapshots may not always be intuitive. If a reservation on filesystem data (but not snapshots) is in effect, then whenever a snapshot is taken, the system must reserve enough space for that snapshot to diverge completely, even if that never occurs. For example, if a 50G filesystem has a 100G reservation without snapshots, then taking the first snapshot will reserve an additional 50G of space, and the filesystem will end up reserving 150G of space total. If there is insufficient space to guarantee complete divergence of data, then taking the snapshot will fail.
Reservations are managed through the BUI under Shares -> General -> Space Usage -> Data. They are managed in the CLI as the reservation and reservation_snap properties.
When you create a LUN the full physical space you configure for the LUN is reserved and cannot be used by other file systems (unless it is thinly provisioned). For replication, when you take a snapshot of a LUN of any given size, up to twice the size of the LUN is also reserved, depending on how much of the LUN space has been used.
The following list shows the maximum overhead space required when replicating a LUN:
