Skip Navigation Links | |
Exit Print View | |
Oracle® ZFS Storage Appliance Customer Service Manual For ZS3-x, 7x20 Controllers, and DE2-24, Sun Disk Shelves |
Chapter 2 Hardware Maintenance
Disconnecting the RJ-45 Cable from the Cluster Serial Port
Storage, Power, and Fan Components
Motherboard, Memory, and PCIe Cards
ZS3-2 CRU Maintenance Procedures
Required Tools and Information
Prepare the Controller for Servicing Internal Components
ZS3-2 Prepare the Controller for Servicing Internal Components
Extend the Storage Controller From the Rack
ZS3-2 Controller Replacement Tasks
Replacing the ZS3-2 Controller SSDs and HDDs
Replacing the ZS3-2 Controller Power Supplies
Replacing the ZS3-2 Controller Fan Modules
Replacing the ZS3-2 Controller Memory
Replacing the ZS3-2 Controller PCIe Cards and Risers
Replacing the ZS3-2 Controller USB Flash Drive
Replacing the ZS3-2 Controller Battery
Oracle DE2 and Sun Disk Shelf Interoperability
ZS3-4 CRU Maintenance Procedures
ZS3-4 Controller Replacement Tasks
Replacing the ZS3-4 Controller HDD or SSD
Replacing the ZS3-4 Controller Fan Module
Replacing the ZS3-4 Controller Power Supply
Replacing the ZS3-4 Controller Memory
Replacing the ZS3-4 Controller PCIe Cards and Risers
Replacing the ZS3-4 Controller Battery
Power Distribution, Fan Module and Disk Components
Standalone Controller Configurations
7320 CPU and Memory Components
7320 Power Distribution and Fan Module Components
7320 Single and Cluster Controller Configurations
7x20 CRU Maintenance Procedures
7x20 Controller Replacement Tasks
Replacing the 7x20 Controller HDD or SSD
Replacing the 7x20 Controller Fan Module
Replacing the 7x20 Controller Power Supply
Replacing the 7x20 Controller Memory
Replacing the 7x20 Controller PCIe Cards and Risers
Replacing the 7x20 Controller Battery
Oracle Storage Drive Enclosure DE2-24P
Oracle Storage Drive Enclosure DE2-24C
Disk Shelf Maintenance Procedures
Electrostatic Discharge Precautions
Shelf Electrostatic Discharge Precautions
Removing Power from the Disk Shelf
Remove Power from the Disk Shelf
Connecting to Attached Storage
This section describes connecting to the controller Service Processor (SP) and configuration considerations for maximum serviceability. In rare cases, faults associated with uncorrectable CPU errors are not diagnosable or displayed in the controller. These faults will be preserved by and observable on the ILOM. The following sections describe how to connect to and manage faults for these cases.
Connect to the server ILOM (Service Processor) on the server platform to diagnose hardware faults that do not appear in the BUI.
In a cluster environment, an ILOM connection should be made to each controller.
The server ILOM provides options for (i) network and (ii) serial port connectivity. Network connection is the preferred choice, as the ILOM serial port does not always allow adequate means of platform data collection.
All standalone controllers should have at least one NIC port configured as a management interface. Select the Allow Admin option in the BUI to enable BUI connections on port 215 and CLI connections on ssh port 22.
All cluster installations should have at least one NIC port on each controller configured as a management interface as described above. In addition, the NIC instance number must be unique on each controller. For example, nodeA uses igb0 and nodeB uses igb1, so that neither may be used as a cluster data interface. In addition, these interfaces must be locked to the controller using the Configuration -> Cluster option in the BUI. In some cases, this may require installation of an additional network interface card on each controller in a cluster configuration.
If access to the appliance data interfaces is impossible for any reason, the management network interface will maintain BUI and CLI access. During a cluster takeover, interfaces are taken down on the failed controller. So, locked interface configuration is required to gather diagnostic information from a failed controller.
Log in to the server as root using the ILOM CLI. To view server faults, type the following command to list all known faults on the system:
-> show /SP/faultmgmt
The server lists all known faults, for example:
SP/faultmgmt Targets: 0 (/SYS/MB/P0) Properties: Commands: cd show
To clear the CPU fault, type the following command:
-> set /SYS/MB/Pn clear_fault_action=true
For example, to clear a fault on CP0:
-> set /SYS/MB/P0 clear_fault_action=true Are you sure you want to clear /SYS/MB/P0 (y/n)? y
Chapter 10, Cluster Configuration, in Oracle ZFS Storage Appliance Administration Guide .
