Skip Navigation Links
Exit Print View
Oracle® ZFS Storage Appliance Customer Service Manual
For ZS3-x, 7x20 Controllers, and DE2-24, Sun Disk Shelves
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 Introduction
Chapter 2 Hardware Maintenance
Maintenance
Introduction
ZS3-2
ZS3-2 Hardware Overview
Controller Overview
Front Panel
Rear Panel
4x4 SAS-2 HBA
Serial Management Connector
Network Management Connector
Ethernet Ports
Cluster I/O Ports
Disconnecting the RJ-45 Cable from the Cluster Serial Port
Physical Specifications
Electrical Specifications
Acoustic Noise Emissions
Internal Components
Storage, Power, and Fan Components
Internal Cables
Motherboard, Memory, and PCIe Cards
CPU and Memory
NIC/HBA Options
PCIe Riser Configuration
PCIe Options
PCIe Slot Order
Optional Cable Management Arm
Attached Storage
ZS3-4
ZS3-4 Hardware Overview
Controller Overview
Chassis Dimensions
Front Panel
System Drives
Rear Panel
4x4 SAS-2 HBA
Internal Boards
Components
CPU and Memory
Fan Modules
NIC/HBA Options
Connectors
PCIe Options
PCIe Slot Order
Attached Storage
ZS3-2
ZS3-2 CRU Maintenance Procedures
Prerequisites
Safety Information
Required Tools and Information
Chassis Serial Number
Prepare the Controller for Servicing Internal Components
ZS3-2 Prepare the Controller for Servicing Internal Components
Remove Power
Extend the Storage Controller From the Rack
Remove the Top Cover
Controller Replacement Tasks
ZS3-2 Controller Replacement Tasks
SSDs and HDDs
Replacing the ZS3-2 Controller SSDs and HDDs
Power Supplies
Replacing the ZS3-2 Controller Power Supplies
Fan Modules
Replacing the ZS3-2 Controller Fan Modules
Memory
Replacing the ZS3-2 Controller Memory
PCIe Cards and Risers
Replacing the ZS3-2 Controller PCIe Cards and Risers
USB Flash Drive
Replacing the ZS3-2 Controller USB Flash Drive
Battery
Replacing the ZS3-2 Controller Battery
Oracle DE2 and Sun Disk Shelf Interoperability
ZS3-4
ZS3-4 CRU Maintenance Procedures
Prerequisites
Safety Information
ZS3-4 Controller Replacement Tasks
HDD or SSD
Replacing the ZS3-4 Controller HDD or SSD
Fan Module
Replacing the ZS3-4 Controller Fan Module
Power Supply
Replacing the ZS3-4 Controller Power Supply
Memory
Replacing the ZS3-4 Controller Memory
Replacing the ZS3-4 Controller PCIe Cards and Risers
Battery
Replacing the ZS3-4 Controller Battery
7120
7120 Hardware Overview
Chassis Overview
Front Panel
Rear Panel
Internal Components
I/O Components
Cables
CPU and Memory
Power Distribution, Fan Module and Disk Components
Standalone Controller Configurations
NIC/HBA Options
PCIe Options
Attached Storage
7320
7320 Hardware Overview
Chassis Overview
Boards
Cables
7320 I/O Components
7320 CPU and Memory Components
7320 Power Distribution and Fan Module Components
7320 Front Panel
7320 Replaceable Components
7320 PCIe Cards and Risers
7320 Rear Panel
7320 Single and Cluster Controller Configurations
7320 Cluster Configurations
7320 Connector Pinouts
Attached Storage
See Also
7420
7420 Hardware Overview
Appliance Overview
Chassis
Front Panel
System Drives
Rear Panel
Connectors
Internal Boards
Components
CPU and Memory
Fan Modules
NIC/HBA Options
PCIe Options
PCIe Slot Order
Attached Storage
7x20
7x20 CRU Maintenance Procedures
Prerequisites
Safety Information
7x20 Controller Replacement Tasks
HDD or SSD
Replacing the 7x20 Controller HDD or SSD
Fan Module
Replacing the 7x20 Controller Fan Module
Power Supply
Replacing the 7x20 Controller Power Supply
Memory
Replacing the 7x20 Controller Memory
Replacing the 7x20 Controller PCIe Cards and Risers
Battery
Replacing the 7x20 Controller Battery
Shelf
Disk Shelf Overview
SAS-2
Front Panel
Drive Locations
Front Panel Indicators
Back Panel
I/O Module Indicators
SIM Board Indicators
Power Supply Indicators
Disk Shelf Configurations
Oracle Storage Drive Enclosure DE2-24P
Oracle Storage Drive Enclosure DE2-24C
Sun Disk Shelf (DS2)
Shelf
Disk Shelf Maintenance Procedures
Prerequisites
Safety Information
Electrostatic Discharge Precautions
Shelf Electrostatic Discharge Precautions
Removing Power from the Disk Shelf
Remove Power from the Disk Shelf
Tasks
Disk Shelf Replacement Tasks
Drives
Replacing a Drive
Power Supply
Replacing a Power Supply
I/O Module
Replacing an I/O Module
SIM Board
Replacing a SIM Board
Faults
Hardware Faults
Connect to ILOM
Management Port Configuration
Observing and Clearing CPU faults from ILOM
See Also
Cabling
Connecting to Attached Storage
Maximum Number of Disk Shelves per Controller Configuration
Next Steps
Chapter 3 System Maintenance
Chassis Overview
The Sun ZFS Storage 7320 consists of either a single storage controller or two storage controllers in a high availability cluster configuration. Both the single and clustered configuration supports one to six disk shelves.
The 7320 controller base configuration includes two CPUs, built-in 4 x 1Gb/s front-end GigE ports, redundant power supplies, NIC options for expanded front-end support, tape backup, InfiniBand, and dual port SAS HBA for storage expansion.
The CPUs are Intel Xeon 5600 series, 2.40GHz, 80W, with 4 core processors. The standard memory configuration is 96GB, 6 x 8GB DDR3-1333 low voltage (LV) DIMMs per CPU. Memory can be upgraded to 144GB using 9 x 8GB DDR3-1333 LV DIMMs per CPU (for a total of 18 x 8GB for two CPUs). Earlier versions of the 7320 controller included 24GB (base), 48GB, or 72GB memory options. The clustered configuration simply uses two servers and a cluster card in each server for a heartbeat connection between the servers.
All user-accessible storage is provided by one to six disk shelves that are external to the server(s). RAID functions are managed by software. Solid state 18GB SAS-1 drives ( 7320 SAS-2) are used for a high-performance write cache (known as LogZilla) or ZFS intent log (ZIL) devices, and are used in place of up to four of the 24 drives in a disk shelf. The remaining 20 drives are available for storage.
Refer to the product site at http://www.oracle.com/us/products/servers-storage/storage/unified-storage/index.htmlhttp://www.oracle.com/us/products/servers-storage/storage/unified-storage/index.html for the most recent component specification.
The 7320 is a SAS-2 (Serial Attached SCSI 2.0) device that consists of an HBA, disk shelf, and disks (1TB and 2TB SAS-2). The SAS-2 storage fabric supports a greater number of targets, greater bandwidth, higher reliability, and bigger scale than the SAS-1 fabric.
Boards
The 7320 storage controller chassis has the following boards installed.
Note -  Field-replaceable units (FRUs) should only be replaced by trained Oracle service technicians.
The following list contains the replaceable system boards for the 7320 storage controller.
Table 2-19  7320 Controller Replaceable System Boards
Part Number
Description
FRU/CRU
F541-2883-01
X8 PCIe Riser Card 1U
CRU
F541-2885-01
X16 PCIe Riser Card 1U
CRU
F541-4081-01
RoHS Motherboard and Tray
FRU
F511-1489-01
DB, Power Distribution Board
FRU
F511-1548-01
PCB, 8 Disk 1U Backplane
FRU
F541-4275-02
PCBA, Connector Board, 1U
FRU
Cables
The following list contains the replaceable cables for the 7320 storage controller.
Table 2-20  7320 Controller Replaceable Cables
Part Number
Description
FRU/CRU
F530-4228-01
Cable, Mini SAS
FRU (internal)
F530-3927-01
FRU,CBL,PDB,MB,1U+2U,RIBBON
FRU (internal)
F530-4431-01
Cable, Fan data
FRU (internal)
F530-4417-01
FRU Cable, Fan paddle
FRU (internal)
F530-3880-01
Cable, Assembly, Ethernet, Shielded, RJ45-RJ45, 6m
CRU (external)
F530-3883-01
FRU,2M,4X Mini SAS Cable
CRU (external)
7320 I/O Components
The following figure and legend identify the I/O components of the storage controller.
Figure 2-35  7320 Controller I/O Components
image:graphic showing 7320 controller I/O components
Figure Legend
1 Top cover
2 Left Control Panel Light Pipe Assembly
3 Drive Cage
4 Solid State Drives
5 blank/USB Module
6 Right Control Panel Light Pipe Assembly
The following list contains the replaceable CPU and memory components of the 7320.
Table 2-21  7320 Controller Replaceable CPU and Memory Components
Part Number
Description
FRU/CRU
F371-4966-01
DIMM, 8GB, DDR3, 2RX4, 13
CRU
F371-4885-01
Intel E5620, 2.40G
FRU
The storage controller motherboard has 18 slots in two groups that hold industry-standard DDR3 DIMM memory cards. All sockets must be occupied by either a filler or a DDR3 DIMM.
Figure 2-36  7320 Controller CPU and Memory Components
image:graphic showing 7320 controller CPU and memory components
The following figure and legend identify the Power Distribution/Fan Module components of the storage controller.
Figure 2-37  7320 Controller Power Distribution and Fan Module Components
image:graphic showing 7320 controller power distribution and fan module components
Figure Legend
1 Fan Modules
4 Power Distribution/Bus Bar Assembly
2 Fan Board
5 Power Supplies
3 Paddle Board
The following list shows the electrical specifications for the 7320.
Note -  The power dissipation numbers listed are the maximum rated power numbers for the power supply. The numbers are not a rating of the actual power consumption of the appliance.
Connectors
Input
Output
Power Dissipation
7320 Front Panel
The following figure and legend identify the front panel LEDs.
Figure 2-38  7320 Controller Front Panel LEDs
image:graphic showing 7320 controller front panel LEDs
Figure Legend
1 Locate Button/LED
2 Service Required LED (amber)
3 Power/OK LED (green)
4 Power Button
5 Rear Power Supply
6 System Overtemperature LED
7 Top Fan
The following figure and legend identify the 7320 front panel drive locations. Two mirrored hard disk drives (HDDs) that store the operating system reside in slots 0 and 1. Up to four solid state drives (ReadZilla SSDs), which store the read cache, fill slots 2 through 5, in order. Slots 6 and 7 are empty and must contain drive fillers.
Figure 2-39  7320 Controller Front Panel Drive Locations
image:graphic showing 7320 controller front panel drive locations Table 2-22  7320 Controller Front Panel Drive Locations
Disk Drive Locations
HDD1
HDD3
HDD5
HDD0
HDD2
HDD4
HDD6
HDD7
