Skip Navigation Links
Exit Print View
Oracle® ZFS Storage Appliance Customer Service Manual
For ZS3-x, 7x20 Controllers, and DE2-24, Sun Disk Shelves
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 Introduction
Chapter 2 Hardware Maintenance
Maintenance
Introduction
ZS3-2
ZS3-2 Hardware Overview
Controller Overview
Front Panel
Rear Panel
4x4 SAS-2 HBA
Serial Management Connector
Network Management Connector
Ethernet Ports
Cluster I/O Ports
Disconnecting the RJ-45 Cable from the Cluster Serial Port
Physical Specifications
Electrical Specifications
Acoustic Noise Emissions
Internal Components
Storage, Power, and Fan Components
Internal Cables
Motherboard, Memory, and PCIe Cards
CPU and Memory
NIC/HBA Options
PCIe Riser Configuration
PCIe Options
PCIe Slot Order
Optional Cable Management Arm
Attached Storage
ZS3-4
ZS3-4 Hardware Overview
Controller Overview
Chassis Dimensions
Front Panel
System Drives
Rear Panel
4x4 SAS-2 HBA
Internal Boards
Components
CPU and Memory
Fan Modules
NIC/HBA Options
Connectors
PCIe Options
PCIe Slot Order
Attached Storage
ZS3-2
ZS3-2 CRU Maintenance Procedures
Prerequisites
Safety Information
Required Tools and Information
Chassis Serial Number
Prepare the Controller for Servicing Internal Components
ZS3-2 Prepare the Controller for Servicing Internal Components
Remove Power
Extend the Storage Controller From the Rack
Remove the Top Cover
Controller Replacement Tasks
ZS3-2 Controller Replacement Tasks
SSDs and HDDs
Replacing the ZS3-2 Controller SSDs and HDDs
Power Supplies
Replacing the ZS3-2 Controller Power Supplies
Fan Modules
Replacing the ZS3-2 Controller Fan Modules
Memory
Replacing the ZS3-2 Controller Memory
PCIe Cards and Risers
Replacing the ZS3-2 Controller PCIe Cards and Risers
USB Flash Drive
Replacing the ZS3-2 Controller USB Flash Drive
Battery
Replacing the ZS3-2 Controller Battery
Oracle DE2 and Sun Disk Shelf Interoperability
ZS3-4
ZS3-4 CRU Maintenance Procedures
Prerequisites
Safety Information
ZS3-4 Controller Replacement Tasks
HDD or SSD
Replacing the ZS3-4 Controller HDD or SSD
Fan Module
Replacing the ZS3-4 Controller Fan Module
Power Supply
Replacing the ZS3-4 Controller Power Supply
Memory
Replacing the ZS3-4 Controller Memory
Replacing the ZS3-4 Controller PCIe Cards and Risers
Battery
Replacing the ZS3-4 Controller Battery
7120
7120 Hardware Overview
Chassis Overview
Front Panel
Rear Panel
Internal Components
I/O Components
Cables
CPU and Memory
Power Distribution, Fan Module and Disk Components
Standalone Controller Configurations
NIC/HBA Options
PCIe Options
Attached Storage
7320
7320 Hardware Overview
Chassis Overview
Boards
Cables
7320 I/O Components
7320 CPU and Memory Components
7320 Power Distribution and Fan Module Components
7320 Front Panel
7320 Replaceable Components
7320 PCIe Cards and Risers
7320 Rear Panel
7320 Single and Cluster Controller Configurations
7320 Cluster Configurations
7320 Connector Pinouts
Attached Storage
See Also
7420
7420 Hardware Overview
Appliance Overview
Chassis
Front Panel
System Drives
Rear Panel
Connectors
Internal Boards
Components
CPU and Memory
Fan Modules
NIC/HBA Options
PCIe Options
PCIe Slot Order
Attached Storage
7x20
7x20 CRU Maintenance Procedures
Prerequisites
Safety Information
7x20 Controller Replacement Tasks
HDD or SSD
Replacing the 7x20 Controller HDD or SSD
Fan Module
Replacing the 7x20 Controller Fan Module
Power Supply
Replacing the 7x20 Controller Power Supply
Memory
Replacing the 7x20 Controller Memory
Replacing the 7x20 Controller PCIe Cards and Risers
Battery
Replacing the 7x20 Controller Battery
Shelf
Disk Shelf Overview
SAS-2
Front Panel
Drive Locations
Front Panel Indicators
Back Panel
I/O Module Indicators
SIM Board Indicators
Power Supply Indicators
Disk Shelf Configurations
Oracle Storage Drive Enclosure DE2-24P
Oracle Storage Drive Enclosure DE2-24C
Sun Disk Shelf (DS2)
Shelf
Disk Shelf Maintenance Procedures
Prerequisites
Safety Information
Electrostatic Discharge Precautions
Shelf Electrostatic Discharge Precautions
Removing Power from the Disk Shelf
Remove Power from the Disk Shelf
Tasks
Disk Shelf Replacement Tasks
Drives
Replacing a Drive
Power Supply
Replacing a Power Supply
I/O Module
Replacing an I/O Module
SIM Board
Replacing a SIM Board
Faults
Hardware Faults
Connect to ILOM
Management Port Configuration
Observing and Clearing CPU faults from ILOM
See Also
Cabling
Connecting to Attached Storage
Maximum Number of Disk Shelves per Controller Configuration
Next Steps
Chapter 3 System Maintenance
In compliance with the requirements defined in ISO 7779, the workplace-dependent noise level of this product is less than 70 db (A).
