Skip Navigation Links
Exit Print View
Oracle® ZFS Storage Appliance Customer Service Manual
For ZS3-x, 7x20 Controllers, and DE2-24, Sun Disk Shelves
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 Introduction
Chapter 2 Hardware Maintenance
Maintenance
Introduction
ZS3-2
ZS3-2 Hardware Overview
Controller Overview
Front Panel
Rear Panel
4x4 SAS-2 HBA
Serial Management Connector
Network Management Connector
Ethernet Ports
Cluster I/O Ports
Disconnecting the RJ-45 Cable from the Cluster Serial Port
Physical Specifications
Electrical Specifications
Acoustic Noise Emissions
Internal Components
Storage, Power, and Fan Components
Internal Cables
Motherboard, Memory, and PCIe Cards
CPU and Memory
NIC/HBA Options
PCIe Riser Configuration
PCIe Options
PCIe Slot Order
Optional Cable Management Arm
Attached Storage
ZS3-4
ZS3-4 Hardware Overview
Controller Overview
Chassis Dimensions
Front Panel
System Drives
Rear Panel
4x4 SAS-2 HBA
Internal Boards
Components
CPU and Memory
Fan Modules
NIC/HBA Options
Connectors
PCIe Options
PCIe Slot Order
Attached Storage
ZS3-2
ZS3-2 CRU Maintenance Procedures
Prerequisites
Safety Information
Required Tools and Information
Chassis Serial Number
Prepare the Controller for Servicing Internal Components
ZS3-2 Prepare the Controller for Servicing Internal Components
Remove Power
Extend the Storage Controller From the Rack
Remove the Top Cover
Controller Replacement Tasks
ZS3-2 Controller Replacement Tasks
SSDs and HDDs
Replacing the ZS3-2 Controller SSDs and HDDs
Power Supplies
Replacing the ZS3-2 Controller Power Supplies
Fan Modules
Replacing the ZS3-2 Controller Fan Modules
Memory
Replacing the ZS3-2 Controller Memory
PCIe Cards and Risers
Replacing the ZS3-2 Controller PCIe Cards and Risers
USB Flash Drive
Replacing the ZS3-2 Controller USB Flash Drive
Battery
Replacing the ZS3-2 Controller Battery
Oracle DE2 and Sun Disk Shelf Interoperability
ZS3-4
ZS3-4 CRU Maintenance Procedures
Prerequisites
Safety Information
ZS3-4 Controller Replacement Tasks
HDD or SSD
Replacing the ZS3-4 Controller HDD or SSD
Fan Module
Replacing the ZS3-4 Controller Fan Module
Power Supply
Replacing the ZS3-4 Controller Power Supply
Memory
Replacing the ZS3-4 Controller Memory
Replacing the ZS3-4 Controller PCIe Cards and Risers
Battery
Replacing the ZS3-4 Controller Battery
7120
7120 Hardware Overview
Chassis Overview
Front Panel
Rear Panel
Internal Components
I/O Components
Cables
CPU and Memory
Power Distribution, Fan Module and Disk Components
Standalone Controller Configurations
NIC/HBA Options
PCIe Options
Attached Storage
7320
7320 Hardware Overview
Chassis Overview
Boards
Cables
7320 I/O Components
7320 CPU and Memory Components
7320 Power Distribution and Fan Module Components
7320 Front Panel
7320 Replaceable Components
7320 PCIe Cards and Risers
7320 Rear Panel
7320 Single and Cluster Controller Configurations
7320 Cluster Configurations
7320 Connector Pinouts
Attached Storage
See Also
7420
7420 Hardware Overview
Appliance Overview
Chassis
Front Panel
System Drives
Rear Panel
Connectors
Internal Boards
Components
CPU and Memory
Fan Modules
NIC/HBA Options
PCIe Options
PCIe Slot Order
Attached Storage
7x20
7x20 CRU Maintenance Procedures
Prerequisites
Safety Information
7x20 Controller Replacement Tasks
HDD or SSD
Replacing the 7x20 Controller HDD or SSD
Fan Module
Replacing the 7x20 Controller Fan Module
Power Supply
Replacing the 7x20 Controller Power Supply
Memory
Replacing the 7x20 Controller Memory
Replacing the 7x20 Controller PCIe Cards and Risers
Battery
Replacing the 7x20 Controller Battery
Shelf
Disk Shelf Overview
SAS-2
Front Panel
Drive Locations
Front Panel Indicators
Back Panel
I/O Module Indicators
SIM Board Indicators
Power Supply Indicators
Disk Shelf Configurations
Oracle Storage Drive Enclosure DE2-24P
Oracle Storage Drive Enclosure DE2-24C
Sun Disk Shelf (DS2)
Shelf
Disk Shelf Maintenance Procedures
Prerequisites
Safety Information
Electrostatic Discharge Precautions
Shelf Electrostatic Discharge Precautions
Removing Power from the Disk Shelf
Remove Power from the Disk Shelf
Tasks
Disk Shelf Replacement Tasks
Drives
Replacing a Drive
Power Supply
Replacing a Power Supply
I/O Module
Replacing an I/O Module
SIM Board
Replacing a SIM Board
Faults
Hardware Faults
Connect to ILOM
Management Port Configuration
Observing and Clearing CPU faults from ILOM
See Also
Cabling
Connecting to Attached Storage
Maximum Number of Disk Shelves per Controller Configuration
Next Steps
Chapter 3 System Maintenance
The ZS3-2 controller motherboard, memory, and PCIe components are described in the following figure and legend.
Note -  Field replaceable components (FRUs) are not customer-serviceable, and must be replaced by trained Oracle service technicians.
Figure 2-10  ZS3-2 Controller Motherboard, Memory, and PCIe Components
image:graphic showing ZS3-2 controller motherboard, memory, and PCIe components
Figure Legend
1 Drive cage (FRU)
5 Airduct
9 Battery
2 Drive backplane (FRU)
6 PCIe Risers (FRU)
10 PDB duct
3 Motherboard (FRU)
7 PCIe cards
11 Power distribution board (FRU)
4 DIMMs
8 USB flash drive
CPU and Memory
The ZS3-2 controller motherboard has 16 slots in two groups that hold industry-standard DDR3 low voltage (LV) DIMMS.
Figure 2-11  ZS3-2 Controller CPU and Memory Components
image:graphic showing ZS3-2 controller CPU and memory components
Note -  All sockets must be occupied by identical DDR3 DIMMs.
Table 2-4  ZS3-2 Controller CPU Descriptions
Capacity
CPU 0
CPU 1
256GB
D0, D2, D5, D7 (blue)
D1, D3, D4, D6 (white)
The ZS3-2 controller replaceable memory components and part numbers are listed below.
Table 2-5  ZS3-2 Controller Replaceable Memory Components
Component
Description
FRU/CRU
Part Number
CPU
Intel E5-2658, 2.1G, 8-core
FRU
7019701
Memory
DIMM, 16GB,DDR3,1600,2Rx4,1.35V
CRU
7041603
Memory
DIMM, 32GB,DDR3,1066,4Rx4,1.35V
CRU
7055964
NIC/HBA Options
The following table describes the NIC/HBA options for the ZS3-2 controller. See PCIe Options for slot allocations.
Table 2-6  ZS3-2 Controller NIC/HBA Options
Mktg Part Number
Description
SG-SAS6-INT-Z
8-port 6Gb/s SAS-2 internal HBA
SG-XPCIE2FC-QF8-Z
2-port 8Gb FC HBA
7103791
4-port (4x4) SAS-2 6Gb/s external HBA
7101674
2-port 16Gb FC HBA
X1109A-Z
2-port 10GbE SFP+ NIC
X4242A
2-port InfiniBand CX2 HCA
7100477
4-port 1Gb Ethernet Copper UTP NIC
7100488
2-port 10Gb Ethernet Copper Base-T NIC
X2129A
XCVR 850NM, 1/10GPS, SFP, short reach
X5562A-Z
10GbE/1GbE SFP+ Transceiver, long reach
The three risers are labeled Riser 1, Riser 2, and Riser 3. Though similar, the risers are not interchangeable. Riser 1 installs at the left rear of the chassis, Riser 2 at the center rear, and Riser 3 at the right rear of the chassis. Each riser can accommodate two PCIe cards:
PCIe Options
The following table describes the supported PCIe configuration options for the ZS3-2 controller. Slots 1 and 2 are reserved for internal and external HBAs, as shown in the following table. When adding PCIe cards, populate from higher order slots (6) first toward lower order slots.
Note -  Any empty PCIe slots must have a filler panel installed.
Table 2-7  ZS3-2 Controller PCIe Configuration Options
Slot
Mfg Part Number
Description
Max
Note
1
7047852
8-port SAS-2 internal HBA
1
Base configuration
2
7067091
4-port (4x4) SAS-2 external HBA
2
Base configuration
3
7067091
2
Second 4x4-port SAS-2 external HBA
3
7070195
4
Optional recommended front-end
3
371-4325-02
2-port 8Gb FC HBA
4
Optional FC target or initiator (backup)
3
7023303
2-port 16Gb FC HBA
4
3
375-3696-01
4
3
7051223
2-port 10Gb Ethernet Optical NIC
4
3
7070006
4
4-6
7070195
4
4-6
371-4325-02
2-port 8Gb FC HBA
4
4-6
7023303
2-port 16Gb FC HBA
4
4-6
375-3696-01
4
4-6
7051223
4
4-6
7070006
4
PCIe Slot Order
Install optional PCIe cards in the following order:
  1. Install optional second 4x4 SAS-2 HBA (7067091) in slot 3.
    Note -  For the remainder of PCIe option cards, always start installing in slot 6 and then work down to slot 3 in this order:
  2. Install InfiniBand CX2 HCA (375-3696-01) in slot 6 and continue until all InfiniBand options are installed and or,
  3. Install 10Gb Ethernet Optical NICs (7051223) and or,
  4. Install 10Gb Ethernet Copper NICs (7070006) and or,
  5. Install 8Gb FC HBAs (371-4325-02) or 16Gb FCs HBA (7023303) and or,
  6. Install 1Gb Ethernet Copper NICs (7070195).
