Skip Navigation Links
Exit Print View
Oracle® ZFS Storage Appliance Customer Service Manual
For ZS3-x, 7x20 Controllers, and DE2-24, Sun Disk Shelves
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 Introduction
Chapter 2 Hardware Maintenance
Maintenance
Introduction
ZS3-2
ZS3-2 Hardware Overview
Controller Overview
Front Panel
Rear Panel
4x4 SAS-2 HBA
Serial Management Connector
Network Management Connector
Ethernet Ports
Cluster I/O Ports
Disconnecting the RJ-45 Cable from the Cluster Serial Port
Physical Specifications
Electrical Specifications
Acoustic Noise Emissions
Internal Components
Storage, Power, and Fan Components
Internal Cables
Motherboard, Memory, and PCIe Cards
CPU and Memory
NIC/HBA Options
PCIe Riser Configuration
PCIe Options
PCIe Slot Order
Optional Cable Management Arm
Attached Storage
ZS3-4
ZS3-4 Hardware Overview
Controller Overview
Chassis Dimensions
Front Panel
System Drives
Rear Panel
4x4 SAS-2 HBA
Internal Boards
Components
CPU and Memory
Fan Modules
NIC/HBA Options
Connectors
PCIe Options
PCIe Slot Order
Attached Storage
ZS3-2
ZS3-2 CRU Maintenance Procedures
Prerequisites
Safety Information
Required Tools and Information
Chassis Serial Number
Prepare the Controller for Servicing Internal Components
ZS3-2 Prepare the Controller for Servicing Internal Components
Remove Power
Extend the Storage Controller From the Rack
Remove the Top Cover
Controller Replacement Tasks
ZS3-2 Controller Replacement Tasks
SSDs and HDDs
Replacing the ZS3-2 Controller SSDs and HDDs
Power Supplies
Replacing the ZS3-2 Controller Power Supplies
Fan Modules
Replacing the ZS3-2 Controller Fan Modules
Memory
Replacing the ZS3-2 Controller Memory
PCIe Cards and Risers
Replacing the ZS3-2 Controller PCIe Cards and Risers
USB Flash Drive
Replacing the ZS3-2 Controller USB Flash Drive
Battery
Replacing the ZS3-2 Controller Battery
Oracle DE2 and Sun Disk Shelf Interoperability
ZS3-4
ZS3-4 CRU Maintenance Procedures
Prerequisites
Safety Information
ZS3-4 Controller Replacement Tasks
HDD or SSD
Replacing the ZS3-4 Controller HDD or SSD
Fan Module
Replacing the ZS3-4 Controller Fan Module
Power Supply
Replacing the ZS3-4 Controller Power Supply
Memory
Replacing the ZS3-4 Controller Memory
Replacing the ZS3-4 Controller PCIe Cards and Risers
Battery
Replacing the ZS3-4 Controller Battery
7120
7120 Hardware Overview
Chassis Overview
Front Panel
Rear Panel
Internal Components
I/O Components
Cables
CPU and Memory
Power Distribution, Fan Module and Disk Components
Standalone Controller Configurations
NIC/HBA Options
PCIe Options
Attached Storage
7320
7320 Hardware Overview
Chassis Overview
Boards
Cables
7320 I/O Components
7320 CPU and Memory Components
7320 Power Distribution and Fan Module Components
7320 Front Panel
7320 Replaceable Components
7320 PCIe Cards and Risers
7320 Rear Panel
7320 Single and Cluster Controller Configurations
7320 Cluster Configurations
7320 Connector Pinouts
Attached Storage
See Also
7420
7420 Hardware Overview
Appliance Overview
Chassis
Front Panel
System Drives
Rear Panel
Connectors
Internal Boards
Components
CPU and Memory
Fan Modules
NIC/HBA Options
PCIe Options
PCIe Slot Order
Attached Storage
7x20
7x20 CRU Maintenance Procedures
Prerequisites
Safety Information
7x20 Controller Replacement Tasks
HDD or SSD
Replacing the 7x20 Controller HDD or SSD
Fan Module
Replacing the 7x20 Controller Fan Module
Power Supply
Replacing the 7x20 Controller Power Supply
Memory
Replacing the 7x20 Controller Memory
Replacing the 7x20 Controller PCIe Cards and Risers
Battery
Replacing the 7x20 Controller Battery
Shelf
Disk Shelf Overview
SAS-2
Front Panel
Drive Locations
Front Panel Indicators
Back Panel
I/O Module Indicators
SIM Board Indicators
Power Supply Indicators
Disk Shelf Configurations
Oracle Storage Drive Enclosure DE2-24P
Oracle Storage Drive Enclosure DE2-24C
Sun Disk Shelf (DS2)
Shelf
Disk Shelf Maintenance Procedures
Prerequisites
Safety Information
Electrostatic Discharge Precautions
Shelf Electrostatic Discharge Precautions
Removing Power from the Disk Shelf
Remove Power from the Disk Shelf
Tasks
Disk Shelf Replacement Tasks
Drives
Replacing a Drive
Power Supply
Replacing a Power Supply
I/O Module
Replacing an I/O Module
SIM Board
Replacing a SIM Board
Faults
Hardware Faults
Connect to ILOM
Management Port Configuration
Observing and Clearing CPU faults from ILOM
See Also
Cabling
Connecting to Attached Storage
Maximum Number of Disk Shelves per Controller Configuration
Next Steps
Chapter 3 System Maintenance
Components
The components of the ZS3-4 controller are shown in the following figure and identified in the legend.
Figure 2-17  ZS3-4 Controller Components
image:graphic showing ZS3-4 controller components
Figure Legend
1 Motherboard
7 CPUs and heatsinks
2 Low-profile PCIe cards
8 Memory risers
3 Power supplies
9 Fan board
4 Power supply backplane
10 Fan modules
5 Drive backplane
11 Boot drives and SSDs
6 System lithium battery
CPU and Memory
The ZS3-4 controller supports 16GB DDR3 DIMMs installed on all eight risers, accommodating 1TB of memory.
Figure 2-18  ZS3-4 Controller DIMM Risers
image:graphic showing ZS3-4 controller DIMM risers
Refer to the service label on the cover for DIMM placement information. On every memory riser, slots D0, D2, D4, and D6 must be populated; optionally, slots D1, D3, D5, and D7 may be populated as a group on all installed memory risers. All DIMMs in the system must be identical.
Figure 2-19  ZS3-4 Controller DIMM Placement
image:graphic showing ZS3-4 controller DIMM placement
DIMM names in appliance logs and the Maintenance > Hardware view are displayed with the full name, such as /SYS/MB/P0/D7.
Fan Modules
The Fan Modules and Fan Module LEDs of the controller are shown in the following figure. The following LEDs are lit when a fan module fault is detected:
Figure 2-20  ZS3-4 Controller Fan Modules
image:graphic showing ZS3-4 controller fan modules
The system Overtemp LED might light if a fan fault causes an increase in system operating temperature.
NIC/HBA Options
This table describes NIC/HBA PCIe card options for ZS3-4 standalone and cluster configurations.
Table 2-10  ZS3-4 Controller NIC/HBA Options
Mktg Part Number
Description
SG-SAS6-INT-Z
8-port 6Gb/s SAS-2 internal HBA
SG-XPCIE2FC-QF8-Z
2-port 8Gb FC HBA
7103791
4-port (4x4) SAS-2 6Gb/s external HBA
7101674
2-port 16Gb FC HBA
7100477
4-port 1Gb Ethernet Copper UTP
7100488
2-port 10Gb Ethernet Copper Base-T
X4242A
2-port InfiniBand CX2 HCA
X1109A-Z
2-port 10GbE SFP+ NIC
X2129A
Transceiver 850NM, 1/10GPS, Short Reach, SFP
X5562A-Z
Transceiver 10GbE/1GbE, Long Reach, SFP
Connectors
The serial management connector (SER MGT) is an RJ-45 connector and provides a terminal connection to the SP console.
Figure 2-21  ZS3-4 Controller Serial Management Port
image:graphic showing ZS3-4 controller serial management port
The network management connector (NET MGT) is an RJ-45 connector and provides a LAN interface to the SP console.
Figure 2-22  ZS3-4 Controller Network Management Port
image:graphic showing ZS3-4 controller network management port
There are four RJ-45 Gigabit Ethernet connectors (NET0, NET1, NET2, NET3) located on the motherboard that operate at 10/100/1000 Mbit/sec. These network interfaces must be configured before use.
PCIe Options
This table describes the PCIe base configuration and optional slot assignments for ZS3-4 standalone and cluster configurations.
Table 2-11  ZS3-4 Controller PCIe Options
Slot
Mfg Part Number
Description
Max
Note
0
7047852
8-port SAS-2 internal HBA
1
Base configuration
1
7067091
4-port (4x4) SAS-2 external HBA
4
Base configuration
2
7067091
4
Additional optional back-end
2
7070006
2-port 10Gb Ethernet Copper NIC
4
Optional recommended front-end
2
375-3696-01
4
2
7070195
4-port 1Gb Ethernet Copper UTP NIC
4
2
7051223
2-port 10Gb Ethernet Optical NIC
6
2
371-4325-02
2-port 8Gb FC HBA
4
Optional FC target or initiator (backup)
2
7023303
2-port 16Gb FC HBA
4
3
7070006
4
3
375-3696-01
4
3
7070195
4
3
7051223
6
3
371-4325-02
2-port 8Gb FC HBA
4
3
7023303
2-port 16Gb FC HBA
4
4
7070006
4
4
375-3696-01
4
4
7070195
4
4
7051223
6
4
371-4325-02
2-port 8Gb FC HBA
4
4
7023303
2-port 16Gb FC HBA
4
C
511-1496-05
Cluster Controller 200
1
Cluster base configuration
5
7070006
4
5
375-3696-01
4
5
7070195
4-port 1GbE UTP Ethernet
4
5
7051223
6
5
371-4325-02
2-port 8Gb FC HBA
4
5
7023303
2-port 16Gb FC HBA
4
6
7070006
4
6
375-3696-01
4
6
7070195
4
6
7051223
6
6
371-4325-02
2-port 8Gb FC HBA
4
6
7023303
2-port 16Gb FC HBA
4
7
7067091
4-port (4x4) external HBA
4
7
7070006
4
7
371-4325-02
2-port 8Gb FC HBA
4
7
375-3696-01
4
7
7051223
6
7
7070195
4
7
371-4325-02
2-port 8Gb FC HBA
4
7
7023303
2-port 16Gb FC HBA
4
8
7067091
4
Base configuration
9
371-4325-02
2-port 8Gb FC HBA
4
9
7070006
4
9
7070195
4
9
7051223
6
9
7023303
2-port 16Gb FC HBA
4
PCIe Slot Order
When installing additional PCIe cards to your base configuration, cards must be added in a specific order.
Note -  Slot 0 is always populated with a SAS-2 internal HBA. Slots 1 and 8 are reserved for 4x4 SAS-2 external HBAs.
Figure 2-23  ZS3-4 Controller PCIe Cards Slot Order
image:graphic showing ZS3-4 controller PCIe cards slot order
Install optional PCIe cards in the following order:
Table 2-12  ZS3-4 Controller Optional PCIe Cards and Slot Order
PCIe Card
Slot Order
1. 4-port (4x4) SAS-2 external HBA
Slot 2, 7
2. 8Gb FC HBA
Slot 9
Additional FC HBAs are installed last
3. InfiniBand HCAs
Slot 3, 6, 4, 5, 2, 7
4. 2-port 10Gb Ethernet NIC
Slot 3, 6, 4, 5, 2, 7, 9
Note: If you are adding a 2-port 10Gb Ethernet Optical NIC and 2-port 10Gb Ethernet Copper NIC, the 10Gb Ethernet Optical NIC has slot priority.
5. 4-port 1Gb Ethernet NIC
6. 16Gb FC HBA
7. Remaining 8Gb FC HBAs
Slot 3, 6, 4, 5, 2, 7 (slot 9, see step 2)
