Skip Navigation Links
Exit Print View
Oracle® ZFS Storage Appliance Customer Service Manual
For ZS3-x, 7x20 Controllers, and DE2-24, Sun Disk Shelves
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 Introduction
Chapter 2 Hardware Maintenance
Maintenance
Introduction
ZS3-2
ZS3-2 Hardware Overview
Controller Overview
Front Panel
Rear Panel
4x4 SAS-2 HBA
Serial Management Connector
Network Management Connector
Ethernet Ports
Cluster I/O Ports
Disconnecting the RJ-45 Cable from the Cluster Serial Port
Physical Specifications
Electrical Specifications
Acoustic Noise Emissions
Internal Components
Storage, Power, and Fan Components
Internal Cables
Motherboard, Memory, and PCIe Cards
CPU and Memory
NIC/HBA Options
PCIe Riser Configuration
PCIe Options
PCIe Slot Order
Optional Cable Management Arm
Attached Storage
ZS3-4
ZS3-4 Hardware Overview
Controller Overview
Chassis Dimensions
Front Panel
System Drives
Rear Panel
4x4 SAS-2 HBA
Internal Boards
Components
CPU and Memory
Fan Modules
NIC/HBA Options
Connectors
PCIe Options
PCIe Slot Order
Attached Storage
ZS3-2
ZS3-2 CRU Maintenance Procedures
Prerequisites
Safety Information
Required Tools and Information
Chassis Serial Number
Prepare the Controller for Servicing Internal Components
ZS3-2 Prepare the Controller for Servicing Internal Components
Remove Power
Extend the Storage Controller From the Rack
Remove the Top Cover
Controller Replacement Tasks
ZS3-2 Controller Replacement Tasks
SSDs and HDDs
Replacing the ZS3-2 Controller SSDs and HDDs
Power Supplies
Replacing the ZS3-2 Controller Power Supplies
Fan Modules
Replacing the ZS3-2 Controller Fan Modules
Memory
Replacing the ZS3-2 Controller Memory
PCIe Cards and Risers
Replacing the ZS3-2 Controller PCIe Cards and Risers
USB Flash Drive
Replacing the ZS3-2 Controller USB Flash Drive
Battery
Replacing the ZS3-2 Controller Battery
Oracle DE2 and Sun Disk Shelf Interoperability
ZS3-4
ZS3-4 CRU Maintenance Procedures
Prerequisites
Safety Information
ZS3-4 Controller Replacement Tasks
HDD or SSD
Replacing the ZS3-4 Controller HDD or SSD
Fan Module
Replacing the ZS3-4 Controller Fan Module
Power Supply
Replacing the ZS3-4 Controller Power Supply
Memory
Replacing the ZS3-4 Controller Memory
Replacing the ZS3-4 Controller PCIe Cards and Risers
Battery
Replacing the ZS3-4 Controller Battery
7120
7120 Hardware Overview
Chassis Overview
Front Panel
Rear Panel
Internal Components
I/O Components
Cables
CPU and Memory
Power Distribution, Fan Module and Disk Components
Standalone Controller Configurations
NIC/HBA Options
PCIe Options
Attached Storage
7320
7320 Hardware Overview
Chassis Overview
Boards
Cables
7320 I/O Components
7320 CPU and Memory Components
7320 Power Distribution and Fan Module Components
7320 Front Panel
7320 Replaceable Components
7320 PCIe Cards and Risers
7320 Rear Panel
7320 Single and Cluster Controller Configurations
7320 Cluster Configurations
7320 Connector Pinouts
Attached Storage
See Also
7420
7420 Hardware Overview
Appliance Overview
Chassis
Front Panel
System Drives
Rear Panel
Connectors
Internal Boards
Components
CPU and Memory
Fan Modules
NIC/HBA Options
PCIe Options
PCIe Slot Order
Attached Storage
7x20
7x20 CRU Maintenance Procedures
Prerequisites
Safety Information
7x20 Controller Replacement Tasks
HDD or SSD
Replacing the 7x20 Controller HDD or SSD
Fan Module
Replacing the 7x20 Controller Fan Module
Power Supply
Replacing the 7x20 Controller Power Supply
Memory
Replacing the 7x20 Controller Memory
Replacing the 7x20 Controller PCIe Cards and Risers
Battery
Replacing the 7x20 Controller Battery
Shelf
Disk Shelf Overview
SAS-2
Front Panel
Drive Locations
Front Panel Indicators
Back Panel
I/O Module Indicators
SIM Board Indicators
Power Supply Indicators
Disk Shelf Configurations
Oracle Storage Drive Enclosure DE2-24P
Oracle Storage Drive Enclosure DE2-24C
Sun Disk Shelf (DS2)
Shelf
Disk Shelf Maintenance Procedures
Prerequisites
Safety Information
Electrostatic Discharge Precautions
Shelf Electrostatic Discharge Precautions
Removing Power from the Disk Shelf
Remove Power from the Disk Shelf
Tasks
Disk Shelf Replacement Tasks
Drives
Replacing a Drive
Power Supply
Replacing a Power Supply
I/O Module
Replacing an I/O Module
SIM Board
Replacing a SIM Board
Faults
Hardware Faults
Connect to ILOM
Management Port Configuration
Observing and Clearing CPU faults from ILOM
See Also
Cabling
Connecting to Attached Storage
Maximum Number of Disk Shelves per Controller Configuration
Next Steps
Chapter 3 System Maintenance
Use the following procedures to replace the ZS3-4 controller:
HDD or SSD
Note -  If you have more than one failed drive, replace only one drive at a time. Removing more than one drive in quick succession causes a hardware/pool fault.
  1. Identify the failed HDD or SSD by going to the Maintenance > Hardware section of the BUI and clicking the drive information icon image: . If you are physically at the system, the amber Service Required indicator on the HDD or SSD should be illuminated.
  2. If you are not physically at the system, turn on the locator indicator by clicking the locator icon image: .
  3. Push the release button on the HDD or SSD to open the latch.
  4. Grasp the latch (2), and pull the drive out of the drive slot.
    image:graphic showing how to remove a ZS3-4 controller disk drive
  5. After 15 seconds, navigate to the Hardware > Maintenance screen, and click the right-arrow icon image: on the system controller to verify that the software has detected that the drive is not present.
  6. Slide the replacement drive into the slot until it is fully seated.
    image:graphic showing how to install a ZS3-4 controller disk drive
  7. Close the latch to lock the drive in place.
  8. The Oracle ZFS Storage system software automatically detects and configures the new drive. The device appears in the BUI Maintenance > Hardware screen when you view details for the controller or drive shelf.
Fan Module
Fan modules are hot-swappable and can be removed and installed while the storage controller is running without affecting other hardware capabilities.
The following illustration shows the fan modules in the ZS3-4 storage controller.
Figure 2-24  ZS3-4 Controller Fan Modules
image:graphic showing the ZS3-4 controller fan modules
Caution
Caution  -  Operating a controller for an extended period of time with fans removed reduces the effectiveness of the cooling system. For this reason, the replacement fan should be unpacked in advance and ready to insert into the controller chassis as soon as the faulted fan is removed.
  1. To locate the chassis you want to service, click the associated locator icon image: on the Maintenance > Hardware screen of the BUI or issue the set /SYS/LOCATE status=on command at the service processor (SP) prompt. The locate LED will flash on the controller chassis.
  2. Verify that no cables will be damaged or will interfere when the storage controller is extended from the rack.
  3. From the front of the storage controller, release the two slide release latches.
  4. While squeezing the slide release latches, slowly pull the storage controller forward until the slide rails latch.
  5. Identify the faulted fan module by locating the corresponding Service Required status indicator or by clicking the locator icon image: on Maintenance > Hardware screen of the BUI for the fan you want to replace.
  6. Lift the latch at the top of the fan module to unlock the fan module, and pull the fan module out.
    image:graphic showing how to remove and install a ZS3-4 controller fan module
  7. Unlock and insert the fan module.
  8. Apply firm pressure to fully seat the fan module.
  9. Verify that the Fan OK status indicator is lit and that the fault status indicator on the replaced fan module is dim.
  10. Verify that the Top Fan status indicator, the Service Required status indicators, and the Locator status indicator/Locator button are dim.
  11. Push the release tabs on the side of each rail and slowly slide the storage controller into the rack.
Power Supply
Storage controllers are equipped with redundant hot-swappable power supplies. If a power supply fails and you do not have a replacement, leave the failed power supply installed to ensure proper air flow. A faulted power supply is indicated by an amber colored status LED.
  1. Gain access to the rear of the storage controller where the faulted power supply is located.
  2. If a cable management arm (CMA) is installed, press and hold the CMA release tab and rotate the arm out of the way.
    image:graphic showing how to release the ZS3-4 controller cable management arm
  3. Disconnect the power cord from the faulted power supply.
  4. Remove the power supply.
  5. Grasp the power supply handle and press the release latch to remove the power supply.
    image:graphic showing how to remove a ZS3-4 controller power supply
  6. Align the replacement power supply with the empty power supply chassis bay.
  7. Slide the power supply into the bay until it is fully seated. The following figure shows the power supply.
    image:graphic showing how to install a ZS3-4 controller power supply
  8. Connect the power cord to the power supply.
  9. Verify that the green AC Present status indicator is lit.
  10. Close the CMA, inserting the CMA into the rear left rail bracket.
  11. Go to the Maintenance > Hardware screen of the BUI. Click the right-arrow icon image: for the controller and then click power supply to verify that the online icon image: is green for the newly installed power supply.
Memory
To identify a specific memory module that has faulted, you must open the storage controller and use the amber status LEDs on the motherboard. To identify a general memory fault, go to the Maintenance > Hardware screen of the BUI, and click on the right-arrow icon image: on the controller. Then click DIMMs to locate the faulted component, indicated by the warning icon image: .
You must shut down the appliance before beginning this task. Note that there will be a loss of access to the storage unless the system is in a clustered configuration. Shut down the appliance using one of the following methods:
Caution
Caution  -  This procedure requires that you handle components that are sensitive to static discharge, which can cause the component to fail. To avoid damage, wear an antistatic wrist strap and use an antistatic mat when handling components.
  1. Disconnect the AC power cords from the rear panel of the storage controller.
  5. To remove the top cover:
    Simultaneously lift both cover latches in an upward motion.
    image:graphic showing how to remove the ZS3-4 controller top cover
    Lift up and remove the top cover.
  6. To locate the DIMM you want to service, press the Fault Remind Button on the storage controller.
    The following illustration shows the Fault remind button on the ZS3-4 controller.
    image:graphic showing the location of the ZS3-4 controller fault remind button
  7. Identify the memory riser that hosts the faulted DIMM by the Service Required status indicator. Lift the memory riser straight up to remove it from the motherboard, and place it on an antistatic mat.
    image:graphic showing how to remove a ZS3-4 controller memory riser from the motherboard
  8. Rotate both DIMM slot ejectors outward as far as they will go and carefully lift the faulted DIMM straight up to remove it from the socket.
    image:graphic showing how to remove a ZS3-4 controller DIMM
  9. Line up the replacement DIMM with the connector, aligning the notch with the key to ensure that the component is oriented correctly.
    image:Image
  10. Push the DIMM into the connector until the ejector tabs lock the component in place.
  11. To replace the cover:
    Push the memory riser module into the associated CPU memory riser slot until the riser module locks in place.
    image:graphic showing how to install a ZS3-4 controller memory riser module
    Place the top cover on the chassis so that it is forward of the rear of the storage controller by about an inch (2.5 cm).
    Slide the top cover toward the rear of the chassis until it seats and press down on the cover with both hands until both latches engage.
    image:graphic showing how to replace the ZS3-4 controller top cover
  12. Push the release tabs on the side of each rail and slowly push the storage controller into the rack.
    image:graphic showing how to push the release tabs on the rails
    The following image shows the chassis.
    image:graphic showing how to push the ZS3-4 controller into the rack
  13. Connect the power cords to the power supplies.
  14. Verify that standby power is on, indicated by the Power/OK status indicator flashing on the front panel about two minutes after the power cords are plugged in.
  15. Use a pen or other pointed object to press and release the recessed Power button on the storage controller front panel.
    The Power/OK status indicator next to the Power button lights and remains lit. The Maintenance > Hardware screen of the BUI provides status of the replacement on the Details page for DIMMs.
Go to the Maintenance > Hardware screen of the BUI and click the right-arrow icon image: on the controller, and then click Slots to locate the faulted component.
All HBAs must be of the same type. Ensure that you upgrade your system software before installing a newly-released HBA.
You must shut down the controller before beginning this task. Note that there will be a loss of access to the storage unless the system is in a clustered configuration. Shut down the appliance using one of the following methods:
Caution
  6. Locate the PCIe card position in the storage controller, see PCIe Options.
  7. To replace the PCIe card:
    Disengage the PCIe card slot crossbar from its locked position and rotate the crossbar into an upright position.
    image:graphic showing how to disengage a ZS3-4 controller PCIe card slot crossbar
    Remove the retaining screw that holds the PCIe card to the chassis.
    Carefully remove the PCIe card from the connector and clean the slot with filtered, compressed air if necessary.
    Install the replacement PCIe card into the PCIe card slot.
    Install the retaining screw to hold the PCIe card to the chassis.
    Return the crossbar to its closed and locked position.
    image:graphic showing how to close a ZS3-4 controller PCIe card slot crossbar
  8. To install the top cover:
    Place the top cover on the chassis (1) so that it is forward of the rear of the storage controller by about an inch (2.5 cm).
    Slide the top cover toward the rear of the chassis (2) until it seats.
    Press down on the cover with both hands until both latches engage.
  9. Push the release tabs on the side of each rail and slowly push the storage controller into the rack, making sure no cables obstruct the path of the controller.
  10. Connect the power cords to the power supplies.
  11. Verify that standby power is on, indicated by the Power/OK status indicator flashing on the front panel about two minutes after the power cords are plugged in.
  12. Use a pen or other pointed object to press and release the recessed Power button on the storage controller front panel. The Power/OK status indicator next to the Power button lights and remains lit.
  13. Connect data cables to the PCIe card, routing them through the cable management arm.
  14. Go to the Maintenance > Hardware screen of the BUI, and click the right-arrow icon image: on the controller. Then, click Slots to verify the status of the new component. The online icon image: should be green.
  15. Install the disk shelf as described in Installation in Oracle ZFS Storage Appliance Installation Guide and connect the expansion storage as described in Connecting to Attached Storage.
Battery
You might need to replace the battery if the storage controller fails to maintain the proper time when powered off and disconnected from the network. You will need a small (No.1 flat-blade) non-metallic screwdriver or equivalent.
  6. Lift up and remove the top cover.
  7. Using a small, non-metallic screwdriver, press the latch and remove the battery from the motherboard. The battery is shown here.
    image:graphic showing how to remove the ZS3-4 controller battery
  8. Press the replacement battery into the motherboard with the positive side (+) facing upward.
  9. To install the top cover:
  10. Push the release tabs on the side of each rail and slowly push the storage controller into the rack, making sure no cables obstruct the path of the controller.
  11. Connect the power cords to the power supplies.
  12. Verify that standby power is on, indicated by the Power/OK status indicator flashing on the front panel about two minutes after the power cords are plugged in.
  13. Use a pen, or other pointed object, to press and release the recessed Power button on the storage controller front panel. The Power/OK status indicator next to the Power button lights and remains lit.
  14. Connect data cables to the PCIe card, routing them through the cable management arm.
  15. When the system has finished booting, log in and set the time using the steps in the task NTP BUI Clock in Oracle ZFS Storage Appliance Administration Guide .
