Skip Navigation Links | |
Exit Print View | |
Oracle® ZFS Storage Appliance Customer Service Manual For ZS3-x, 7x20 Controllers, and DE2-24, Sun Disk Shelves |
Chapter 2 Hardware Maintenance
Managing Support Bundles Using the BUI
Generating and Uploading a Support Bundle Using the BUI
Managing Support Bundles Using the CLI
Scheduling Software Notification Using the BUI
Scheduling Software Notification Using the CLI
Checking for Updates Using the BUI
Checking for Updates Using the CLI
Troubleshooting Update Health Check Failures
Actions to Take to Resolve Health Check Alerts
Steps for Resolving Health Check Alerts
Performing the Cluster Upgrade
Applying Deferred Updates (CLI)
Triple-Parity RAID Deferred Update
Data Deduplication Deferred Update
Received Properties Deferred Update
Snapshot Deletion Deferred Update
Recursive Snapshots Deferred Update
Multiple Initiator Groups per LUN
Managing Configuration Backups Using the BUI
Restore from a Saved Configuration
Managing Configuration Backups Using the CLI
Alert Action Execution Context
Problems can be repaired by performing the steps described in the suggested action section. This typically involves replacing the physical component (for hardware faults) or reconfiguring and restarting the affected service (for software defects). Repaired problems no longer appear on this screen.
While the system typically detects repairs automatically, in some cases manual intervention may be required. If a problem persists after the affected components have been repaired, contact support. You may be instructed to mark the problem repaired. This should only be done under the direction of service personnel or as part of a documented Oracle repair procedure.
