Skip Navigation Links | |
Exit Print View | |
Oracle® ZFS Storage Appliance Customer Service Manual For ZS3-x, 7x20 Controllers, and DE2-24, Sun Disk Shelves |
Chapter 2 Hardware Maintenance
Managing Support Bundles Using the BUI
Generating and Uploading a Support Bundle Using the BUI
Managing Support Bundles Using the CLI
Scheduling Software Notification Using the BUI
Scheduling Software Notification Using the CLI
Checking for Updates Using the BUI
Checking for Updates Using the CLI
Troubleshooting Update Health Check Failures
Actions to Take to Resolve Health Check Alerts
Steps for Resolving Health Check Alerts
Performing the Cluster Upgrade
Applying Deferred Updates (CLI)
Triple-Parity RAID Deferred Update
Data Deduplication Deferred Update
Received Properties Deferred Update
Snapshot Deletion Deferred Update
Recursive Snapshots Deferred Update
Multiple Initiator Groups per LUN
Managing Configuration Backups Using the BUI
Restore from a Saved Configuration
Managing Configuration Backups Using the CLI
Alert Action Execution Context
Initial setup steps through the tasks performed as part of the initial configuration as described in Chapter 3, Initial Configuration, in Oracle ZFS Storage Appliance Administration Guide . This does not change any of the current settings unless explicitly requested. User data on the storage pool (including projects and shares) is not affected.
To perform an initial setup:
BUI: Click the Initial Setup button on the Maintenance > System screen.
CLI: Enter the maintenance system context, then enter the setup command.
