Skip Navigation Links
Exit Print View
Oracle® ZFS Storage Appliance Customer Service Manual
For ZS3-x, 7x20 Controllers, and DE2-24, Sun Disk Shelves
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 Introduction
Chapter 2 Hardware Maintenance
Chapter 3 System Maintenance
System
Introduction
System Disks
Support Bundles
Managing Support Bundles Using the BUI
Generating and Uploading a Support Bundle Using the BUI
Support Bundle Options
Managing Support Bundles Using the CLI
Initial Setup
Factory Reset
Updates
System Updates
Software Update Notification
Scheduling Software Notification Using the BUI
Scheduling Software Notification Using the CLI
Checking for Updates Using the BUI
Checking for Updates Using the CLI
System Update Overview
Preconditions
Update Health Checks
BUI
CLI
Troubleshooting Update Health Check Failures
Actions to Take to Resolve Health Check Alerts
Resolution Steps
Steps for Resolving Health Check Alerts
Deferred Updates
Reboot After an Update
Hardware Firmware Updates
Rollback
Fail-safe Rollback
Cluster Upgrade
Performing the Cluster Upgrade
Cluster States During Upgrade
Updating via the BUI
Unpacking and Verifying Media
Beginning the Upgrade
Rolling Back
Removing Update Media
Applying Deferred Updates
Updating via the CLI
Beginning an Upgrade
Rolling Back
Applying Deferred Updates (CLI)
Passthrough x
Passthrough-x Deferred Update
User Quotas
User Quotas Deferred Update
COMSTAR
COMSTAR Deferred Update
Triple Parity RAID
Triple-Parity RAID Deferred Update
Dedup
Data Deduplication Deferred Update
Replication
Replication Deferred Update
Received Properties
Received Properties Deferred Update
Slim ZIL
Introduction
Snapshot Deletion
Snapshot Deletion Deferred Update
Recursive Snapshots
Recursive Snapshots Deferred Update
Multi Replace
Multi Replace Deferred Update
RAIDZ Mirror
RAIDZ/Mirror Deferred Update
Optional Child Dir
Introduction
Multiple Initiator Groups per LUN
Introduction
Support for Large Block Sizes
Sequential Resilvering
ConfigurationBackup
Configuration Backup
Backup Contents
Restore Impact
Security Considerations
Managing Configuration Backups Using the BUI
Create a Configuration Backup
Restore from a Saved Configuration
Delete a Saved Configuration
Export a Saved Configuration
Import a Saved Configuration
Managing Configuration Backups Using the CLI
Listing Configurations
Problems
Problems
Active Problems Display
Repairing problems
Related features
Logs
Logs
Alerts
Faults
System
Audit
Phone Home
BUI
Viewing Logs
Exporting Logs
CLI
Listing Logs
Viewing a Log
Viewing All Log Entries
Viewing Groups of Log Entries
Viewing Entry Details
Exporting Logs
Maintenance Workflows
Using Workflows
Workflow Execution Context
Workflow Parameters
Constrained Parameters
Optional Parameters
Workflow Error Handling
Workflow Input Validation
Workflow Execution Auditing
Workflow Execution Reporting
Versioning
Appliance Versioning
Workflow Versioning
Workflows as Alert Actions
Alert Action Execution Context
Auditing Alert Actions
Using Scheduled Workflows
Using the CLI
Coding the Schedule
Example: Device Type Selection
BUI
CLI
Downloading Workflows
Viewing Workflows
Executing Workflows
The 2010.Q1 feature that enables administrators to customize properties on replicated shares relies on a ZFS pool upgrade. This upgrade provides support of persistent local changes to received properties. Before this upgrade has been applied, the system does not allow administrators to change properties on replicated shares.
Applying this update is equivalent to upgrading the on-disk ZFS pool to version 22.
