Skip Navigation Links
Exit Print View
Oracle® ZFS Storage Appliance Customer Service Manual
For ZS3-x, 7x20 Controllers, and DE2-24, Sun Disk Shelves
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 Introduction
Chapter 2 Hardware Maintenance
Chapter 3 System Maintenance
System
Introduction
System Disks
Support Bundles
Managing Support Bundles Using the BUI
Generating and Uploading a Support Bundle Using the BUI
Support Bundle Options
Managing Support Bundles Using the CLI
Initial Setup
Factory Reset
Updates
System Updates
Software Update Notification
Scheduling Software Notification Using the BUI
Scheduling Software Notification Using the CLI
Checking for Updates Using the BUI
Checking for Updates Using the CLI
System Update Overview
Preconditions
Update Health Checks
BUI
CLI
Troubleshooting Update Health Check Failures
Actions to Take to Resolve Health Check Alerts
Resolution Steps
Steps for Resolving Health Check Alerts
Deferred Updates
Reboot After an Update
Hardware Firmware Updates
Rollback
Fail-safe Rollback
Cluster Upgrade
Performing the Cluster Upgrade
Cluster States During Upgrade
Updating via the BUI
Unpacking and Verifying Media
Beginning the Upgrade
Rolling Back
Removing Update Media
Applying Deferred Updates
Updating via the CLI
Beginning an Upgrade
Rolling Back
Applying Deferred Updates (CLI)
Passthrough x
Passthrough-x Deferred Update
User Quotas
User Quotas Deferred Update
COMSTAR
COMSTAR Deferred Update
Triple Parity RAID
Triple-Parity RAID Deferred Update
Dedup
Data Deduplication Deferred Update
Replication
Replication Deferred Update
Received Properties
Received Properties Deferred Update
Slim ZIL
Introduction
Snapshot Deletion
Snapshot Deletion Deferred Update
Recursive Snapshots
Recursive Snapshots Deferred Update
Multi Replace
Multi Replace Deferred Update
RAIDZ Mirror
RAIDZ/Mirror Deferred Update
Optional Child Dir
Introduction
Multiple Initiator Groups per LUN
Introduction
Support for Large Block Sizes
Sequential Resilvering
ConfigurationBackup
Configuration Backup
Backup Contents
Restore Impact
Security Considerations
Managing Configuration Backups Using the BUI
Create a Configuration Backup
Restore from a Saved Configuration
Delete a Saved Configuration
Export a Saved Configuration
Import a Saved Configuration
Managing Configuration Backups Using the CLI
Listing Configurations
Problems
Problems
Active Problems Display
Repairing problems
Related features
Logs
Logs
Alerts
Faults
System
Audit
Phone Home
BUI
Viewing Logs
Exporting Logs
CLI
Listing Logs
Viewing a Log
Viewing All Log Entries
Viewing Groups of Log Entries
Viewing Entry Details
Exporting Logs
Maintenance Workflows
Using Workflows
Workflow Execution Context
Workflow Parameters
Constrained Parameters
Optional Parameters
Workflow Error Handling
Workflow Input Validation
Workflow Execution Auditing
Workflow Execution Reporting
Versioning
Appliance Versioning
Workflow Versioning
Workflows as Alert Actions
Alert Action Execution Context
Auditing Alert Actions
Using Scheduled Workflows
Using the CLI
Coding the Schedule
Example: Device Type Selection
BUI
CLI
Downloading Workflows
Viewing Workflows
Executing Workflows
System Updates
The system update feature provides customers, developers, and field personnel with the ability to update a system's software after the system is installed. You can be notified when new software updates are available on My Oracle Support (MOS) or you can perform an immediate check for updates, using the BUI or CLI.
You can set up periodic checks for software updates, or you can check for updates at any time. When an updated software package is available, you are directed to download the latest package from MOS. To use the update notification feature, the Phone Home service must be enabled, as described in Phone Home Service in Oracle ZFS Storage Appliance Administration Guide .
  1. Be sure the Phone Home service is enabled.
  2. Go to Maintenance > System > Software Updates.
  3. Click the Check box, and select the frequency: daily, weekly, or monthly. When a software update is available on MOS, you will receive an alert notification similar to the following:
    An update is available on My Oracle Support version 2013.1.0.1.
  4. Go to Maintenance > System > Software Updates, and click the download icon image: at the far right.
  5. Click the download link shown in the popup window, and save the zip file.
  2. At the command line, enter configuration services scrk. The following example checks for new software versions every 30 days:
    zfs-appliance:configuration services scrk> ls
    updatecheck_on = false
    time_updatecheck = 7d
    zfs-appliance:configuration services scrk> set updatecheck_on=true
    updatecheck_on = true (uncommitted)
    zfs-appliance:configuration services scrk> set time_updatecheck=30d
    time_updatecheck = 30d (uncommitted)
  3. When you are notified of an update, go to MOS and download the package.
  3. Notice the date of the last software check, displayed next to the Check now link.
  4. Click the Check now link.
  5. When an update is available on MOS, you see the following under STATUS:
    Update available for download
  6. Click the download icon image: , at the far right.
  7. Click the download link shown in the popup window, and save the zip file.
  2. At the command line, enter the following in the maintenance system updates context:
     zfs-appliance:maintenance system updates> show
     Updates:
     UPDATE                          DATE                      STATUS
     2013.1.1.5                      2014-2-18 08:00           downloadable
     ak-nas@2014.01.15,1-0           2014-1-15 14:38:53        previous
     ak-nas@2014.02.01,1-0           2014-2-1 19:38:55         previous
     ak-nas@2014.02.08,1-0           2014-2-8 08:59:04         current
     zfs-appliance:maintenance system updates> select status=downloadable
     zfs-appliance:maintenance system 2013.1.1.5> show
     Properties:
                           version = 2013.1.1.5
                               date = 2014-2-18 08:00
                           status = downloadable
                                url = https://updates.oracle.com/Orion/Services/download
    /p18269573_20131_Generic.zip?aru=17312483&patch_file=p18269573_20131_Generic.zip
                          checkdate = 2014-3-4
Software updates are delivered as opaque binary downloads that contain some or all of:
The updated release notes describe what is in the update, and the update process automates all of the steps of activating the delivered components. The procedure for updating the system is as follows:
For details on the update process using the BUI or CLI, review the following sections.
Preconditions
Best practices include verifying several preconditions prior to applying an update. Whenever possible, administrators should ensure that these preconditions are satisfied immediately prior to applying an update on the storage controller. In a clustered environment, these should be verified on both storage controllers before applying the update to either one.
System-level health checks are provided to help ensure that no pathologies interfere with the software update. If a problem is encountered, it is noted in the Alert Log and the update process is aborted. System software updates do not proceed until all problems have been corrected.
You can manually run the same health checks in advance of any planned update. This allows you to check the state of the system prior to scheduling an update maintenance window so you can correct any problems that could interfere with the update process. Any problem report that is issued by a manual health check is identical to that issued by the health checks integrated in the update process. As with the integrated health checks, you are presented with a link to the Alert Log, as described in Alerts , when problems are found. If no problems are found, the System Ready state transitions to Yes to indicate that the system is ready for software updates.
Note -  Running an update health check does not replace meeting required preconditions. Precondition checks, described in Preconditions, must also be executed and problems resolved prior to updating the system software.
BUI
After you select and start an update, update health checks may be issued from the software update dialog box in the BUI by clicking Check.
Figure 3-1  Starting the Update Health Checks in the BUI
image:graphic showing how to start the Update Health Checks in 									the BUI
The system remains in the Unchecked state until the Check button is clicked. During the health check operation, an indicator shows its progress.
Figure 3-2  Update Health Checks in Progress in the BUI
image:graphic showing the Update Health Checks in progress in the 									BUI
After completion, the System Ready state changes to Yes or No with a link to the Alert Log.
Figure 3-3  Completed Update Health Checks in the BUI
image:graphic showing completed Update Health Checks in the 									BUI
CLI
To execute the update health checks via the CLI, execute the upgrade command in the maintenance system updates context after selecting the update media:
zfs-appliance:maintenance system updates:ak-nas@2013.06.05.0.0,1-1.6> upgrade
This procedure will consume several minutes and requires a system reboot upon
successful update, but can be aborted with [Control-C] at any time prior to
reboot. A health check will validate system readiness before an update is
attempted, and may also be executed independently using the check command.
Are you sure? (Y/N)
 Healthcheck running ... /
 Healthcheck completed.  There are no issues at this time which
 would cause an upgrade to this media to be aborted.
Prior to the actual update, health checks are performed automatically when an update is started. If an update health check fails, it can cause an update to abort (see following example). Update health checks only validate issues that can impact updates.
Figure 3-4  Example BUI and CLI Update Health Checks Failures
image:graphic showing example BUI and CLI Update Health Checks 									failures
zfs-appliance:maintenance system updates ak-nas@2013.06.05.0.0,1-1.6> upgrade
Are you sure? (Y/N)
error: System is not in an upgradeable state: prerequisite healthcheck reports problems.
See alert log for more.
After an update health check failure, you can review the Alert Log and take action to resolve each failure based on the message in the log. The following table lists the update health check failures that can block an update, and describes the associated Alert Log message and recommended order of steps you can take to resolve the issue. For component faults, follow the instructions for removal and installation found in the maintenance procedures for your controller.
Table 3-2  Resolving Health Check Alerts
ID and Alert Log Message
Failure
Resolution Steps
B1 "System software update cannot proceed: Slot <label> in disk shelf <name> is reported as absent."
SIM cannot be detected.
1, 2, 4
B2 "System software update cannot proceed: Slot <label> in disk shelf <name> is faulted."
SIM is faulted.
1, 2, 4
C1 "System software update cannot proceed: Some slots of disk shelf <name> have no firmware revision information."
SIM is missing firmware revision information.
1, 4
C2 "System software update cannot proceed: The slots of disk shelf <name> have non-uniform part numbers."
SIMs report different part numbers.
2, 4
C5 "System software update cannot proceed: The slots of disk shelf <name> have mixed firmware revisions <rev1> and <rev2>."
SIMs report different firmware revisions.
4
E1 "System software update cannot proceed: Disk shelf <name> has <just one path or zero paths>."
Disk shelf does not have two paths.
1, 2, 4
E2 "System software update cannot proceed: Disk shelf <name> path <pathname> is <state>."
Disk shelf path is not online.
1, 2, 4
E3 "System software update cannot proceed: Pool <data or log> disk <label> in disk shelf <name> has <just one path or zero paths>."
Disk or log device that is configured in a pool does not have two paths.
3, 4
PAN1 "Slot <slot> has a Revision B3 SAS HBA; Revision C0 (or later) required."
A revision B3 SAS HBA is present.
4
PAN2 "J4400 and J4500 disk shelves are not supported in this release."
Disk shelf/shelves are present that are not supported for this software release.
V1 "<product> is not supported in this release."
Controller (product) is not supported for this software release.
Resolution Steps
Take the following steps in the order listed above to resolve the issue detected during the upgrade health check.
  1. If a SAS port LED is unlit, check all connections and replace cables as needed.
  2. Identify affected chassis, then disconnect and remove faulted SIM. After two minutes, re-seat SIM and wait for steady Power LED before reconnecting cables.
  3. Identify affected chassis, and remove faulted disk. After 30 seconds, re-seat disk and wait for steady or flashing LED.
  4. Contact Oracle Support for component service or replacement.
Deferred Updates
Each update may come with new firmware or updates to external resources. In general, these updates are backwards-compatible and applied automatically without user intervention. There are exceptions, however, for non-reversible updates. These updates involve updating a resource external to the system software in a way that is incompatible with older software releases. After the update is applied, rolling back to previous versions results in undefined behavior. For these updates, you are always given an explicit option of applying them automatically during upgrade or applying them after the fact. They are, therefore, referred to as "deferred updates."
When applying an update to a version with incompatible version changes, you are given an option to apply these version changes as part of the upgrade. For each version change, the benefits of applying the change are presented to you. The default is to not apply them, requiring you to return to the updates view and apply them once the system has rebooted after the upgrade is applied. This allows you to verify that the rest of the software is functional and a rollback is not required before applying the update.
If you elect to not apply deferred updates during an upgrade, you can return to the updates view at any point to apply the update. If deferred updates are available for the current software version, they appear as a list below the current set of available updates, with an "Apply" button to apply the updates. Deferred updates in a cluster take effect on both storage controllers simultaneously, and can only be applied while both controllers are operational. Because deferred updates are listed only for resources present on the local storage controller, in a cluster it may be the case that deferred updates are available only for resources active on the peer controller. In a cluster, it is therefore necessary to check both storage controllers to determine the availability of deferred updates.
Note -  Replication does not work across deferred updates. After deferred updates are applied that increment the stream format version, it is no longer possible to replicate to an older system. See the "Incompatible Target" failure in section Replication Failures in Oracle ZFS Storage Appliance Administration Guide .
Table 3-3  Deferred Updates
Feature
Version introduced
2009.Q2.0.0
2009.Q3.0.0
2009.Q3.0.0
2009.Q3.0.0
2010.Q1.0.0
2010.Q1.0.0
2010.Q1.0.0
2010.Q3.1.0
2010.Q3.1.0
2010.Q3.1.0
2010.Q3.1.0
2011.1.0.0
2011.1.0.0
2011.1.8.0
2013.1.1.0
2013.1.2.0
Following the completion of the update process, the system reboots automatically. If you have the serial console open, you will notice during this reboot that multiple GRUB menu entries are available, ordered from the newest software (at the top) to the oldest software (at the bottom). The default menu entry is at the top -- the new software to which you just updated. If you do nothing, this entry boots by default, completing the update. The previous entries are rollback targets that can be used to initiate a rollback to previous versions of the system software. Rollback is discussed later.
  GNU GRUB  version 0.97  (612K lower / 2087424K upper memory)
 | Sun ZFS Storage 7120 2013.06.05.0.0,1-1.6                               |
 | Sun ZFS Storage 7120 2011.04.24.4.2,1-1.28                              |
     Use the ^ and v keys to select which entry is highlighted.
     Press enter to boot the selected OS, 'e' to edit the
     commands before booting, or 'c' for a command-line.
As the system boots up using the new system software, you will see some special messages on the first boot indicating that an update is completing and noting the previous and new versions of the system software:
SunOS Release 5.11 Version ak/generic@2013.06.05.0.0,1-1.6 64-bit
Copyright (c) 1983, 2013, Oracle and/or its affiliates. All rights reserved.
System update in progress.
Updating from: ak/nas@2011.04.24.4.2,1-1.28
Updating to:   ak/nas@2013.06.05.0.0,1-1.6
Cloning active datasets ...... done.
Upgrading /var/ak/home ... 16 blocks
Upgrading /etc/svc/profile ... 176 blocks
Upgrading /var/apache2 ... 4432 blocks
Upgrading /var/sadm ... 5040 blocks
Upgrading /var/svc ... 0 blocks
Upgrading /var/dhcp/duid ... done.
Upgrading /var/pkg ... 208800 blocks
Upgrading /var/ak/logadm.conf ... done.
Adjusting system/dump and system/cores ... done.
Upgrading /var/crypto/pkcs11.conf ... done.
Updating system logs ... done.
Starting primordial svc.configd
Upgrading SMF repository.  This may take several minutes.
   Upgrading from Version 5 to Version 6 :
     11570 of 11570 rows upgraded
   Upgrading from Version 6 to Version 7 :
     6305 of 6305 rows upgraded
   Upgrading from Version 7 to Version 8 :
SMF repository upgrade complete
SMF online in 180 seconds
Sanitizing manifestfiles properties ... done.
Loading smf(5) service descriptions: 162/162
svccfg: Loaded 162 smf(5) service descriptions
Transitioning NFS server properties ... done.
Re-enabling auditing of Solaris commands ... done.
Transitioning network/initial IPMP properties to network/ipmp ... done.
Transitioning name service properties ... done.
Transitioning CIFS server properties ... done.
Preparing for service import ... done.
Importing adconf.xml ... done.
Configuring appliance/kit/identity:default ... done.
Applying service layer ak_generic ... done.
Refreshing services: done.
Applying service layer ak_nas ... done.
Applying service layer ak_SUNW,iwashi_plus ... done.
Applying service profile ak_generic ... done.
Applying profile upgrade/akinstall.xml ... done.
Applying layer upgrade/composite.svc ... done.
Cleaning up services ... done.
Shutting down svc.configd ... done.
Configuring devices.
Configuring network devices.
Sun ZFS Storage 7120 Version ak/SUNW,iwashi_plus@2013.06.05.0.0,1-1.6
Copyright (c) 2008, 2013, Oracle and/or its affiliates. All rights reserved.
dorab console login:
