You can set a number of specific forecast preferences to customize how Crystal Ball calculates and displays forecast charts. These are in addition to the general chart preferences discussed in Setting Chart Preferences.
You can control several forecast features with preference settings:
Change the forecast chart view (Forecast Window Tab)
Determine when the forecast window opens (Forecast Window Tab)
Fit a distribution to the forecast (Fitting a Distribution to a Forecast)
Set precision controls for forecast statistics (Precision Tab)
Filter ranges of forecast values (Filter Tab)
Automatically extract forecast data to a spreadsheet (Auto Extract Tab)
For an overview, see Basic Instructions for Setting Forecast Preferences.
