The Speed tab of the Run Preferences dialog adjusts how fast a simulation runs. Normal speed is the default simulation speed. When you select a speed setting, the Options button is active and you can make additional settings.
For general instructions, see Setting Run Preferences.
The Speed tab of the Run Preferences dialog has these settings:
Options settings — Set update rules for the active worksheet in Normal speed and set processing rate in Demo speed (Speed Tab Options Settings).
Chart Windows settings — Set the redraw rate for any charts open during a simulation.
Bring Microsoft Excel to the foreground while running simulations (faster for large models) — When selected, Microsoft Excel runs in the foreground and performance improves.
