The uniform distribution is continuous. In the uniform distribution, you know the range between the minimum and maximum values and you know that all values in the range are equally likely to occur. It can be used to describe a real estate appraisal or a leak in a pipe.
Parameters
Minimum, Maximum
Conditions
The uniform distribution is used under these conditions:
