Customizing Charts
You can customize Predictor charts in many ways:
  To customize Predictor charts:
  1. In the Predictor Results window, select Preferences, and then Chart Preferences.
  2. In the Chart Preferences dialog, review the Show Series settings:
    • Clear the check box for any series that you do not want to include.
    • Make any wanted line color, line type, or line size changes.
  3. Optional: Review the Options settings:
    • Change the Gridlines setting to display horizontal or vertical gridlines.
    • Change the Legend setting to display or hide the legend and change its position in the chart.
    • Change whether to show or hide the separator line between historical and predicted values.
  4. Optional: Review the Effects settings:
    • Select the 3D chart setting to add three-dimensional perspective.
    • Select the Transparency setting to make the chart lines transparent, according to the number in the percent box.
  5. Click OK to return to the Predictor Results window.
