Configuration - Back Office Interface Market Codes Mapping (cf_bof_mktcodes_map with GENREPPAR.FMX)
Configuration reports for Back Office will only be available if the OPP_BO Back Office Interface add-on license code is active.
The report output is based on the configuration of the mappings for Back Office. This is configured in System Configuration>External>Back Office>Configuration.
Will display all configured Back Office Mappings for Market Codes. These are used when the export files are created by Opera.
For Market Group. A single select LOV is available for filtering on a specific Market Group that is configured for your Property.
