previous
Configuration - Cashiers (cf_cashiers with CFG4.FMX)
The Configuration report for Cashiers will display all configured cashiers for your property. For a multi property environment, this list will contain all cashiers that have been configured in the application, and thus for all properties.
Cashiers are configured in System Configuration>Cashiering>Cashiers.
Selection Criteria
Filter
Cashiers. Multi Select LOV to filter by specific cashiers to display on the report.
Include
Active. Select the check box to include the active cashiers in the report results.
Inactive. Select the check box to include the inactive cashiers in the report results.
