previous
Configuration - Source Codes (cf_sourcecodes with GENREPPAR.FMX)
The Configuration report for Source Codes will display all Source Codes that have been configured in the application. When the OPP_MHOT Opera Property Management Multi-Property Base add-on license code is active, this report will represent all codes on the template form.
Source Codes are configured in Configuration>Rate Management>Codes>Source Codes.
Search Criteria
Active. Select the check box to include active source codes in the report.
Inactive. Select the check box to include the inactive source codes in the report.
