previous
Configuration – Transaction Codes (cf_trxcodes1 with CFG6.FMX)
The Configuration report for Transaction Codes will display all Transaction Codes that have been configured in the application. The report information will be grouped by Transaction Group->Subgroup, and then all corresponding Transaction Codes.
Transaction Groups, Subgroups, and Codes are configured in Configuration>Cashiering>Codes.
Selection Criteria
Filter
Transaction Group. Select the down arrow to select the transaction code group to filter by.
Transaction Subgroup. Select the down arrow to select the transaction code subgroup to filter by.
Transaction Code. Select the down arrow to select the transaction code to use in the report.
Include
When the OPP_GCA PTS Gaming and Comp Accounting license code is active, a check box to Include Comp Transaction Codes is displayed to allow further filtering for the report output.
