previous
DEPOSIT LEDGER TRN CODE Application Setting
Group.  Cashiering
Type.  Setting
Application.  PMS
Description.  Internal Transaction Code used to Transfer Deposit Balances from the Deposit Ledger to the Guest Ledger at the Time of Check In.
Internal Name. DEPOSIT_LED_TRX_CODE
Property Determination. Transaction Code set here is used to Transfer Deposit Balances from the Deposit Ledger to the Guest Ledger at the Time of Check In.
Activation / Inactivation Rules.
OPP_ <version number> OPERA Property Management System license must be active.
Available Values.
All transaction codes associated to a "Payment" group, marked as "Manual Posting" = N, "Front Office Payments" = N, "A/R Payments" = N  "Deposit Payment" = N, "In House Payment" = N, "In House Sales" = N, and "In House Deposit" = N.
Note: This value cannot be changed if a financial transaction exists with the value. But if the transaction code that is selected for this application setting is changed on the transaction code screen by the Change Code in whole system right-click option, this value will be automatically updated.
Add On Licenses/Country Specifics.
<none>
Other Application Settings.
<none>
Affected Areas
Menus / Screens / Fields.
<none>
Reports & Report Forms.
<none>
Permissions.
<none>
Other Areas.
Transaction codes that are selected for anything besides internal use or Others on the Transaction Code Edit form, can't be selected for this application setting.
