Group Departure By Room (grpdepbyroom with GEN1.FMX)
The Groups Departure By Room Number Report displays all the reservations in house, that have a group profile attached. The output is sorted by room number and are grouped by departure date. Print this report to see a list of all departing groups for a specified date.
Group. Select the down arrow to select one or more specific groups to display on the report from the multi-select list of values.
In the report output, if the Reservations>Room Limit Per Reservation application setting is set to 1 and the Reservation>Shares application function is set to N, then the Rms. column will not display.
