Monitor Links
The Service Monitor shows the status of the services that make up the GWIZ application. From this window, users can confirm if the individual services are running. These services are running on the GWIZ server and are stopped/started on the machine.
Typically this Queue is empty. If there are messages in the Queue, it will indicate that the messages are not being picked up by Opera. It is suggested to verify that the services are running. These can be checked in the Service Monitor. If these services are"‘running" but the messages are not being processed, please confirm the status of the Opera database and the local network.
Typically this Queue is empty. If there are messages in the Queue, it will indicate that the messages are not being sent out by Opera. It is suggested to verify that the services are running (GWIZ (OAP) type B Pegasus Server). These can be checked in the Service Monitor. If these services are "running" but the messages are not being processed, please confirm the status of the Opera database and the local network.
The Reservation Fail Queue page will list all bookings that were not processed via Type B (Type B rejects). These bookings must be reviewed manually. Please see steps below.
Re-process. Will process the reservation and send the confirmation number to the Travel Agent. The message is sent to the Type B In Queue and processed as "normal."
Return Error. Returns the booking response with a UC Segment to indicate to the Travel Agent that the request could not be corrected.
Delete. Removes the record from the queue and no response is sent to the Travel Agent.
