Requirements and Assumptions When Installing OEDS for an HTNG Interface
Listed below are the requirements and assumptions when installing the OEDS interface.
Installing OEDS requires installing one of the following operating systems with latest service packs and security patches:
Before running the OEDS Wizard, you must install the following items in the order listed, with the latest service packs and security patches:
Note: For installations using versions 4.0 or higher, Oracle Client 10g must be installed.
Opera Electronic Distribution Suite (OEDS) should only be installed after installing IIS, .Net 2.0, and the Oracle Client. Access the Opera application server on-site and go to the micros/opera/tools directory. In the OEDS folder, copy the OEDS.zip file over to the local PC and extract the contents to a temp directory.
The following concepts and procedures are associated with this section:
