Setting up an HTNG Interface in OXI
In OXI, an HTNG interface is set up in the Interface and Opera Property Configuration screen.
To set up an HTNG interface in OXI, Log into OXI and select "Switch Interface" from the main menu. The Interface and Opera Property Configuration screen appears, displaying all of the available interfaces per property. Select the New button to access the New Interface Setup screen.
Complete the following fields and select the Save button.
Interface. Select the appropriate interface from the list of values.
Note: If you do not see the interface in the list of values, please contact the OXI support desk immediately.
Interface Description. The description of the interface automatically populates based on the interface selected in the Interface field.
Opera Property. Select the Opera resort ID as configured in Opera.
External System Property. The external system ID configured for the interface.
Data Flow. Select the following check boxes:
Message Format. Select the message type used by this external system. For OXI Generic, this will always be XML.
Delta Mode. Select the delta node.
Deletion Indicator. This area allows you to set indicators for deleting data in the Opera system from an incoming message.
See Also |
