previous
Setting Up OEDS Parameters in OXI for an HTNG Interface
The OEDS parameters must be set up in OXI for all HTNG Interfaces. To set up the OEDS parameters in OXI, log in to OXI, select an HTNG interface at the Opera Login prompt, and then select Interface Configuration>Interface Parameters. The Interface Parameter Setup for the Interface XXX and the Property XXX screen appears.
To configure the interface parameters, select a parameter group from the Groups column, select the parameter in the Parameters column, and then select the Edit button.
The following interface groups must be configured for all HTNG interfaces:
OEDS Communication Interface Group Parameters
The following OEDS Communication Interface Group parameters must be configured.
Parameter Name
Parameter Direction of Transmission/Description
ACTIVITY_SERVICE_URL
-> Direction: Data from Opera To External System.
The partner Activity Service URL
NAME_SERVICE_URL
The partner Name Service URL
Note: The value entered for these parameters can be the same.
OEDS Generic Interface Group Parameters
The following OEDS Generic Interface Group parameters must be configured.
Parameter Name
Parameter Direction of Transmission/ Description
BE_MAXIMUM_FAILED_COUNT
Number Of Consecutive Failed Business Events Before BE Service Shutdown, If Set To "0", the Business Event Service will not shutdown.
BE_MAXIMUM_RETRY_COUNT
Number Of Retries Before Skipping A Business Event.
BUSINESS_EVENT_ID
ID To Be Used When Reading Business Events
CONVERT_CODES_YN
Use Conversion Code Functionality. Always set to Yes.
DESTINATION_ADDRESS_ID
-> Direction: Data from Opera to external system
Address/URI Used By The Destination Web Server To Identify The Message Used For Security Reason
EXT_WEB_AUTHENTICATION_PASSRD
-> Direction: Data from external system to Opera
Web Server Authentication Password
EXT_WEB_AUTHENTICATION_USER_NAME
Web Server Authentication User Name
IFC8_INTERFACE_NO
IFC8 Interface Number used for Payment Posting
INTERACTIVE_QUEUE_ID
ID To Be Used When Reading Interactive Queue Message
MAX_ROWS_IN_LOOKUP
Maximum Number Of Rows To Return During Lookup
MESSAGE_TYPE
SOAP Context From Address. Set to HTNG.
SOAP_CONTEXT_FROM_ADDRESS
SOAP Context From Address. Always set to URN:OPERA.
TIMEOUT
Number Of Seconds To Wait when there is not message in Interactive or Business Events Queue.
TIMEOUT_WHEN_ERROR
Number Of Seconds To Wait After A Communication Error.
WEB_AUTHENTICATION_PASSWORD
Web Server Authentication Password.
Web Server Authentication User Name.
OEDS Name Interface Group Parameters
The following OEDS Name Interface Group parameters must be configured.
Parameter Name
DEFAULT_ADDRESS_TYPE
-> Direction: Data from External System to Opera.
Default Address Type to be used when Address Type is not send in the message. The
value set should be external system value before conversion
DEFAULT_PHONE_TYPE
Default Phone Type to be used when Phone Type is not send in the message. The value set should be external system value before conversion
DEFAULT_PROFILE_TYPE
Default Profile Type to be used when Profile Type is not send in the message. The value set should be external system value before conversion
DEST_ENTITY_ID
The Destination Entity ID. Set to EAS.
DEST_SYSTEM_TYPE
The Destination System Type. Set to EAS.
NO_INSERT_ON_UPDATE
If set to "Y", on a profile update and profile does not exist in opera interface will throw an exception. If set to "N" will insert it as a new profile
ORIGIN_ENTITY_ID
The Opera Entity ID. Set to Opera.
ORIGIN_ORGANIZATION_ID
The Origin Organization ID. Set to Property
ORIGIN_SYSTEM_TYPE
The Opera System Type. Set to PMS.
STAGE_PROFILE_REGION
Set to None.
STAGE_PROFILE_SOURCE
Set to Gaming.
SUBSCRIBE_ON_LOOKUP
Subscribe Profile After A Successful Profile Lookup. Set to Yes.
OEDS Reservation Interface Group Parameters
The following OEDS Reservation Interface Group parameters must be configured.
Parameter Name
SEND_SHARE_YN
Send Share Number In Reservation Message. Always set to "N".
