RESERVATION FLOW Application Setting
Group. Reservations |
Type. Setting |
Application. PMS S&C OVOS |
Description. Reservation Flow
Internal Name. RESERVATION FLOW
Property Determination. Depending on the way your property wishes to approach reservation making, the sequence of screens presented to you may vary. For example, reservation making may start from the Rate Query screen, the Property Calendar, the Cross-Selling Sales screen, etc.
Activation / Inactivation Rules. |
The F7 CROSS SELL AND DIRECT option is available when the OPP_MHT2 PMS Multi Property Cross Reservations license code is active. If the F7 CROSS SELL AND DIRECT option is selected and the OPP_MHT2 PMS Multi Property Cross Reservations license code is inactivated, the Reservation Flow setting defaults to DIRECT. |
Available Values. |
DIRECT - Direct to new reservations RATE QUERY - Rate Query Assessment for New Reservation CALENDAR - Property Calendar for New Reservation CALENDAR/GRID - Property Calendar with Rate Grid for New Reservation ROOM PLAN/GRID - Room Plan with Rate Grid for New Reservations F7 CROSS SELL AND DIRECT - Sales Screen "Define Search" for New Reservation. The Sales Screen appears with the Define Search screen open for new reservations when a new reservation is made from the following locations; from other locations, DIRECT will be used:
Add On Licenses/Country Specifics. |
<none> |
Other Application Settings. |
<none> |
Affected Areas
Menus / Screens / Fields. |
New Reservation Walk In Reservation |
Reports & Report Forms. |
<none> |
Permissions. |
<none> |
Other Areas. |
<none> |
