Room Statistics Per Month (statroom with GENREPPAR.FMX)
The Room Statistics Per Month Report displays revenue and room usage by room for each month. This report can be used for monitoring room usage, to keep track of those heavily used rooms needing repairs, or to change room-ordering sequence.
Year. Select the year from the single select list of values.
From Month. Select the beginning month.
To Month. Select the ending month for the report.
From Room No. Select the beginning room number for the report.
To Room No. Select the ending room number for the report.
