2C Monitor
A menu item is now available in the 2c monitor control panel that allows the user to view the Rate Status. This menu item is made available by activating the "Rate Status" option on the 2c Monitor Web Parameters screen when running the OEDS Configuration Editor.
The Rate Status menu item is made available by activating the "Rate Status" option on the 2c Monitor Web Parameters screen when running the OEDS Configuration Editor.
The Rate Status displays rate update message information for a specific date and time.
The screen displays the following message information:
