previous
Configuration - Master Codes (cf_mastercodes with GENREPPAR.FMX)
The Configuration report for Master Codes will display all Master Codes that have been configured in the application. Master codes are found throughout the configuration application and can also be created manually by the property. If the license code for multi property functionality is activated (OPP_MHOT), this report will represent all codes on the template form.
Master Codes are configured manually in System Configuration>Setup>Screen Design>List of Values Maintenance>LOV Group Maintenance and LOV Value Maintenance.
Entity Group.
