previous
Configuration - Cities and Postal Codes (cf_postal_codes with CFG7.FMXs)
The Configuration report for Cities and Postal Codes will display Cities and Postal Codes that have been configured in the application.
States are configured in Configuration > Profile > Geographical Data > Cities and Postal Codes.
Filter
Country. Multi-select LOV to select a specific Country, but the default is ALL.
State. Multi-select LOV to select a specific State, but the default is ALL.
District. Multi-select LOV to select a specific District, but the default is ALL.
City. Enter the city name to display in the report results.
Postal Code From/To. Enter the From and To Postal Code numbers to narrow down the postal codes of a specific city.
